![]() | Home > Puma (Tdci) > Puma 110 Front Brake Calipers |
One is the left hand side and one the right hand side.
Oh hang on do you mean the difference between the part numbers... LR were excellent at superseding parts but not really changing them at all. The front brake calipers are a case in point. The vented calipers are the same right through the Defender range from, as you say, year dot through to the end of production. A side of that is the pads are the same as well.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8480 ![]() ![]() ![]() |
Front calipers are same throughout less vented or solid option Cheers
Albarker55 Member Since: 02 May 2022 Location: Fleet, Hants Posts: 22 ![]() ![]() |
Sorry my explanation was not clear. I would like to understand the difference, if any, between LR061253 and SEB500460, and LR061254 and SEB500470.
I think you have answered my question in your other reply and it looks like my logic was OK! |
James - Many thanks. Looks like the part numbers change only to protect the profit margins!!
And probably changes in suppliers etc as well.
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1363 ![]() ![]() ![]() |
Looking at the calipers I am getting the distinctive impression that the difference between vented and non vented disc is a space piece fitted between the two halves. So really even they are the same no? |
Yes they are the same. Just the addition of the spacer and gallery seals.
Geobloke - Agreed re supplier changing = PN change
