![]() | Home > Puma (Tdci) > Chassis Swap |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3588 ![]() ![]() ![]() |
Perhaps it is a good idea to state the supplier of the new chassis.
Or if it is a galvanized chassis, could the holes be there, but blocked by excess zinc? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
InternationalDBA Member Since: 18 Feb 2018 Location: West Sussex Posts: 37 ![]() ![]() ![]() |
It is a Richards chassis.
I chose it because it was featured in a book I am using to help me. Yes, the chassis is galvanised. I have spent quite a long time painting it black and can confirm that the holes are definitely not there. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17874 ![]() ![]() ![]() |
Drill the required holes, you really don't have a choice.
Incidentally the factory routing of that brake line along the top of the chassis rail makes it a major pain if you ever need to replace the brake pipe (ask me how I know)! If I was in your situation I would look at the possibility of rerouting it along the inside face of the chassis rail instead. |
Drilling will not compromise the rust protection as the ratio of the surface area of the anode (the zinc) to the cathode (the exposed steel in the drilled holes) is massive. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2750 ![]() ![]() |
On non-OEM chassis like Richards you will have to drill the holes yourself.
Even on the OEM Marsland (GKN) ones you usually have to drill out the holes as they end up a few mm smaller with the galv and the clips don’t fit. A dab of paint/wax in the holes will serve to discourage any corrosion. |
Thank you for the replies.
By coincidence I went to my MOT station last Friday with my son and his Fiat 500. The garage is well into Defenders and also said that I may have to drill some holes myself. |
Yup drilling out holes is something you will have to do. Get yourself a nice new set of HSS drill bits a metal stepper drill bit is useful too.
Once drilled you can spray the bare metal with cold galv paint or slather in a grease like Lanoguards motogrease to prevent corrosion. |
