![]() | Home > General & Technical (L663) > 'Bonging Noise / Warning' through the lower Speed Range |
| Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753
Do you have air suspension? It can make a single bong if you have not got it in auto lower/rise mode / access mode and you pull away lowered down and exceed 10mph IIRC, you also should get a brief message on the dash telling you the car is raising to normal height. You will also get bongs if you have pulled away with it locked down in access mode. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
| CEEGEE Member Since: 02 Oct 2013 Location: Yorkshire Posts: 135
Nope, its just on springs
| lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3514
ls there no indication on the display or dashboard to the reason for the bongs?
| Tobers Member Since: 01 Oct 2023 Location: Skye Posts: 49
Inexperienced person here, but possibly helpful…
On my test drives of a D250 HSE, there was repeated annoying bonging as you describe. It was caused by the driver assistance setting being on max, so it bongs at every speed limit change, every time you exceed the speed limit, and so on. To turn it off, I found the driver assistance button on the centre console and pressed it to cycle from max to medium to minimum. Annoyingly it resets to max every time you start the car but it looks to be tweakable by some 3rd party specialists to remember the last setting. |
| colinsb Member Since: 15 Oct 2022 Location: Radnorshire Posts: 49
Correct. I’ve had to learn to press the new Driver Assistance button on the steering wheel three times whenever I start a journey. 90 D250 HSE, Pangea Green with tan interior and fabric sunroof.
...okay, that sounds logical (annoying, but logical) - I will try that later today and will report back.
Thanks |
| RDR Member Since: 27 Apr 2018 Location: Derbyshire Posts: 597
I had a loaner with it it’s very annoying. You can setup the custom profile to not beep it then Takes two presses on the steering wheel button every time you startup. Really annoying feature. 110 MY23.5 X Dynamic HSE
RR MY23 HSE PHEV D5 MY19 HSE - Now Sold D4 MY16 HSE Luxury - Now Sold D4 MY12 HSE - Gone D3 MY06 S - Gone but not forgotten |
ls that a new feature? Only my 2022 only ever bongs to warn me of a speed camera.
Yep on all my24 across all models. 110 MY23.5 X Dynamic HSE
What does it do, just warn you about various things like speed limits?
Be useful in Wales, was there last week and on one stretch of road there were five changes of speed limit in under two miles. Plus a partially hidden speed camera van half way along! With the new 20mph limits it's a nightmare. Plus between Rhyl and Prestatyn there's some truly vicious speed bumps on the side roads. |
These are the four elements and thevthree setting levels. Blame the new General Safety Regularions!
Click image to enlarge 90 D250 HSE, Pangea Green with tan interior and fabric sunroof. |
| Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1448
I'm just hoping they don't spring this on owners with older cars via a Pivi upgrade
-------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
| Nuclear Nick Member Since: 21 Aug 2021 Location: Southwest Posts: 316
Agreed Ian, but I think that could be challenged legally and I’d be the first to join a class action!
The problem is, driving standards are in the main so poor, that people need the car to think for them.
l've just driven locally between two towns and the roads were full of people bashing their big cars about, seemingly either oblivious or just not caring about anything else on the road. |
