Home > For Sale & Wanted > [For Sale] TDS winch motors £95ea |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7706 |
whats the brush pack like? correct i only have splined motors here. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
4th Oct 2023 10:21am |
these motors shown will fit a 12000winch tds yes. i believe all the TDS range had the same size motor it was just the gearing that was changed to give different line pulls and speed. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
4th Oct 2023 10:22am |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5745 |
Cheers, I think my motor might be on the way out (getting slow on winding in a full drum with no load) going to check wiring at the weekend to make sure I have no duff connections. 1999 Defender TD5 110
4th Oct 2023 10:24am |
Not bad, not the worst I have seen. But the F1 and F2 internal windings have perished. So a bit beyond repair I think. So, I think I am on the lookout for an entire second hand winch. Goodness there are some dogs on eBay at the moment and for ridiculous prices |
4th Oct 2023 10:54am |
Hi Jeremy, were you still after one, i see you havent opened my PM reply. James Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
9th Oct 2023 7:39pm |
Just closing off my bit in this thread. I managed to find a Warn 9.5XP in need of some love. Picked it up, stripped it down, rebuilt it and fitted it just this evening. No empty winch bumper on Miffy.
Just need a replacement hook as the one I have is close to past its best. Click image to enlarge |
10th Oct 2023 8:19pm |
Result, good find. Cheers
13th Oct 2023 11:12am |
Hi James. Yes a good find. The 9.5XP is a good winch. I would have loved a Goodwinch TDS 9.5 but
16th Oct 2023 11:33am |
Use it regularly, the 9.5ti need regular and frequent use Cheers
16th Oct 2023 5:26pm |
Check the voltage the motor is getting. Earths may just need a clean? Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
16th Oct 2023 5:27pm |
16th Oct 2023 5:37pm |
Still have some take offs and bow1 and 2 available and Bow2+ Cheers
24th Oct 2023 9:05pm |
Earth was a bit dull, now cleaned up. In fact the whole winch is on the bench for clean up. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
25th Oct 2023 8:48am |
Sounds like permission to play that does It's OK JST says I need to... |
25th Oct 2023 8:52am |
