Home > Technical > 90 Defender towing another 90 Defender
Page 1 of 3 123>
458GT
Can a Defender 90 TD5 or Puma legally/safely tow another 90 (ideal to know for another TD5 / Puma for any weight readings)?
Would be using a 2600kg rated BJT A4 trailer which I believe is 1930kg load capacity according to the website.
If so would 4 over wheel straps be sufficient? Likely leave the winch locked in place too.
Travel is approx 20mi mix of roads, my friends landy is being dropped off for some long term storage and in the absence of spare driver / alternative tow vehicle, hopefully this can suffice...
I'm not a frequent tower for anything other than a much lighter car and so my knowledge is a little rusty on making the correct judgement on this.
Post #1010775 10th Oct 2023 7:30pm
Chugga90
The defender can tow 3500kg
Post #1010780 10th Oct 2023 8:03pm
Of course, why would you have any doubt?
Assuming your license allows it you can tow 3500kg gross behind any classic Defender or series Land-Rover.
Post #1010782 10th Oct 2023 8:05pm
458GT
Thank you, much appreciated!
A google search seems the load will be at the upper limit of the trailer capacity, but otherwise it now seems fine.
Post #1010785 10th Oct 2023 8:32pm
Mdm
strap wise you need all 4 wheels tied down. i would not leave the winch line on as the body will move and may damage the winch as it shock loads the cable.
trl will be on or just over its weight limit but lower speed and non mway will be fine. best to make sure tyres are set to max pressure ( they never are) as this will help.
same goes for the towing truck as it will help handling.
Post #1010789 10th Oct 2023 9:29pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
This was me today (yesterday now....)
Not a 90 pulling a 90, but Tbh it was barely much different with the trailer empty or loaded. 440 miles and half of that with the trailer loaded. For a short, careful trip of only 20 miles, provided you are within the legal and mechanical limits of the tow rig then I would not be worried. IMO the 90 is not the best tow vehicle due to its short wheel base but if properly loaded with the correct nose weight you should be ok.
Might be worth checking the state of the suspension bushes and steering linkages before hooking up that trailer if you are not sure about the tow vehicles condition!
Post #1010809 11th Oct 2023 2:19am
I Like Old Skool
+1 on not attaching the winch to anything. Definitely strap all 4 wheels. For reference, I pumped up my 110 tyres to 36psi front and 42psi rear (usually run at 30 or 32psi all round) and the borrowed trailer was at 50-55psi but tyres rated for max load at 90psi so I put 80psi in them.
Post #1010810 11th Oct 2023 2:26am
NickMc
I would always do the wheels and strap the body down on a longer trip as it kills the wobbles on a defender.
Post #1010921 11th Oct 2023 10:30pm
Personally I prefer where possible to block the suspension on the carried vehicle and use crossed chains with dwangs at each end, rather than wheel straps, unless it's a very short haul, since the trailer and load become a single solid lump allowing the trailer suspension to work properly and without the carried vehicle's suspension bouncing around independently.
It's just a personal preference and possibly OTT but I find the trailer tows more comfortably and predictably and feel it's safer.
Post #1010926 11th Oct 2023 10:56pm
458GT
Thank you all!
All useful / helpful advice to keep in mind. Will be a short haul of mostly lanes and minor carriageway for 2 miles, but at sensible pace so I think it will be fine. Fuel is low on the Defender to be carried so it all helps somewhat with weight.
No issues strapping the wheels down, but when you mention to strap the body down, if I strap via the tow bar to further secure the back, but what about the front?
Post #1010993 12th Oct 2023 3:58pm
I Like Old Skool
Tow hooks, that's what they are for.
Post #1011074 13th Oct 2023 8:51am
nicholas2012
Scotland 2010 Defender 90 Puma 2.4 HT Tamar Blue
Give yourself plenty time with trailers keep it at a pace you're comfortable with always need to be stay alert to driving conditions ahead as others have said towing land rovers or other 4x4s with with bigger suspension travel and higher center of gravity they can rock the trailer take your time (especially on downhills where it's more difficult to slow down with the added push of trailer) and will be right enough Smile
Post #1011264 15th Oct 2023 9:41am
Screbble
I do like the word ‘dwangs’ - as always great advice BW.
Post #1011274 15th Oct 2023 10:23am
I've always wondered about the origin of the word "dwang" in this context (a device for tightening a securing chain). Popular culture says it is an onomatopoeia for the sound the lethal over-centre type makes just before it knocks all your teeth out and smashes your jaw.
(Never use an over-centre dwang if you can help it, they are exceedingly dangerous and the transport industry has been calling for a ban for years. Always use the bottlescrew ratchet type and enjoy a longer life).
Post #1011288 15th Oct 2023 11:19am
458GT
Thank you very useful points that I'm happy to know in advance. Far more confident now doing all that I can Thumbs Up
Post #1011509 17th Oct 2023 7:41am
Page 1 of 3 123>
