![]() | Home > Td5 > Rear wiper wash water issues. |
Cragster69 Member Since: 15 Jun 2021 Location: Scotland Posts: 235 ![]() ![]() ![]() |
Mine runs along the passenger side of the roof, minimal headlining disruption needed to check it, as long as you can get the firtree clips out.
The pipe runs up to the roof inside the plastic trim at the front. Worth checking there first as it's only 2 screws. If you have a leak in the pipe I'd assume there would be a wet patch or water dripping when you push the button. If it works on the windscreen that would rule out an empty windscreen wash bottle. I bought a plastic tool for removing trim clips it lasted 30 seconds before breaking, I have a metal mini crowbar type with a nail remover. Something like this https://www.screwfix.com/p/faithfull-tack-lifter/795rh Craig. “Don't believe everything you read on the internet.” ― Abraham Lincoln www.scotgrc.co.uk Last edited by Cragster69 on 10th Oct 2023 3:58pm. Edited 1 time in total |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17831 ![]() ![]() ![]() |
Not necessarily, the outlet for the rear washer is at a higher level in the reservoir than the outlet for the windscreen washer so that it stops first when the level is getting low. This can be a useful indication that you need to top up. I use the rear washer outlet for my headlamp washers and many times the failure of them to squirt has told me that the fluid needs topping up, before the screen washers have actually conked out. |
Lunar Landy Member Since: 02 Jun 2023 Location: Northamptonshire Posts: 39 ![]() ![]() ![]() |
Hi Blackwolf,
I filled up the reservoir up and tried but no joy and whilst attempting this the noise from the motor stopped so presumably it’s in operative? I think this be a garage job, I assume there are 2 pumps? Thanks |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 973 ![]() ![]() ![]() |
Yes there are two pumps and they can be accessed at the front bottom of the washer fluid tank. See parts diagram attached
https://www.lrworkshop.com/diagrams/land-r...ttle_44953 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2669 ![]() ![]() ![]() |
Just out of interest, have you recently removed the windscreen trim piece {passenger side, RHD) and then replaced it?
The reason for asking is that (no names to protect the guilty here) could you have put the screw through the rear washer pipe? I never use my rear wash wipe and must have taken three or four years to notice..... ![]() |
Craig772 Member Since: 23 May 2022 Location: Cannock, Staffordshire Posts: 75 ![]() ![]() ![]() |
I found the passenger side trim piece around the moulding for the screw had nicked the hose. Looks like it was done when the Nokia phone charging cradle was installed. I found out when removing it and generally going through a list of faults to rectify.
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 364 ![]() ![]() ![]() |
Hiya, in response to your question about non return valves on my Td5 110 they are located in the region of the heater box before they enter the bulkhead. If I were you I'd have a root around there, try and find the pipes as they run along the NS wing and you should find the valves, it makes sense that LR put them somewhere accessible. My rear non-return valve blocked resulting in an MOT failure a while back, any local motor factor will stock them, just makes ure you install them in the correct orientation! |
