Home > Maintenance & Modifications > Puma Wiper Arms
ChrisDefender
Puma Wiper Arms
Hi,
Can anyone shed any light as to how to remove the wiper arms from a Puma - do they just pull off? I have looked online etc but they all seem to refer to older models, and I am not sure if they are the same. Not keen to start pulling at them if they don't just pull off! Mine are looking a bit patchy and thought they could do with replacing or sprucing up.
Many thanks.
Post #1010286 6th Oct 2023 2:13pm
gcc130
Open the plastic cover, undo the nut, 13mm if I remember correctly, and then prise the arm off the splined shaft.
I use two open ended spammers to prise apart.
Post #1010288 6th Oct 2023 2:45pm
geobloke
As above. It is a 13mm flanged nut. You might require a wiper puller, they are not expensive and worth the money IMHO.
Post #1010296 6th Oct 2023 3:02pm
mwestcrew
United Kingdom 2011 Defender 130 Puma 2.4 HCPU Baltic Blue
Wiper puller is one of the best value and most useful tools I have bought recently. 2011 130 Utility Body
2005 110 Van
Post #1010356 6th Oct 2023 9:43pm
ChrisDefender
Hi all,
Many thanks, very helpful.
Cheers.
Post #1010586 9th Oct 2023 8:46am
Dinnu
Wiper puller is a good tool to have.
But if caught in a pinch and need to remove a stuck wiper arm, I had good success using a mole grip (was successful on a very stubborn wiper arm).
Just loosen the nut enough to have good clearance between the base of the nut and the wiper arm (1 to 2mm, but ensure still good thread connection). One jaw underneath the wiper arm, and one jaw on the nut. Adjust the mole grip to get good pressure and should pop off. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1010590 9th Oct 2023 9:15am
