![]() | Home > Faults & Fixes (L663) > LED flasher fluid |
DFNDER Member Since: 02 Oct 2023 Location: Perth WA Posts: 141 ![]() ![]() |
Just wondering if anyone has had issues refilling their LED flasher fluid?
windy81 Member Since: 14 Mar 2018 Location: North Wales Posts: 311 ![]() ![]() ![]() |
Up the wahs aii
pjeski Member Since: 25 Jul 2023 Location: Michigan Posts: 115 ![]() ![]() |
No, he means blinker fluid. It has to be kept full, or your turn signals and hazards will stop flashing.
It's like making sure you change the winter air in your tires for summer air and vice versa to accomodate the seasons. |
Exactly, thanks for the tip on Winter vs. Summer air, I will be sure to change mine soon, I just rotated the tyres at the first 5000km, and had to swap from lh air to rh air.
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 731 ![]() ![]() ![]() |
This might be a good time to remind owners of the classic defender, that when upgrading from filament bulbs to led lights, that led specific fluid must be used. Drain and flush the system with your desired indicator flush, then refill with fully synthetic indicator/blinker fluid. Mineral based fluids can have a peculiar effect in the diodes.
P50WKB Member Since: 05 Jul 2021 Location: Aberdeenshire Posts: 23 ![]() ![]() ![]() |
Surely there's only one April 1st in any 12 month period ?
![]() MY 24 3.0 D250 HSE 90 Santorini Black (Bought October 2023) 2009 Defender 90 2.4 TDCi Santorini Black |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1281 ![]() ![]() |
![]() you can now get a LED trafficator, which are both electrical and mechanical, so keep them oiled. |
thanks for the tip, any specific brands I should look for? 😉 |
I can recommend Vinz synthetic advanced blinker fluid, good for 10k blinks
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3314 ![]() ![]() |
The indicators on my old Morris 8 stopped flashing, they were on all the time.
I tried to buy more flashes but the shop sold me the gaps, and not the actual flashes, so now they don't work at all. |
How much for the gaps? I was quoted the same price per gap as per flash, but Im thinking the gaps should be 50% of the flash as the globe or led isn't actually working.....
Re the fluid, I enquired, and here in Oz I can only get "Winks" synthetic led flasher fluid, it is guaranteed for 20,000 blinks though.... |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 ![]() ![]() ![]() |
So if you change for a different viscosity of fluid can you vary the blinker timing?
![]() If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
steam_simon Member Since: 24 Sep 2022 Location: London Posts: 97 ![]() ![]() |
That "Winks" synthetic LED flasher is rubbish. I turned on my hazard lights and only one side worked. You need to use "Blinks" instead. (Although my indicators no longer work now.) |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1298 ![]() ![]() ![]() |
That's the problem with modern cars they find more and more ways for you to part with your money.
Dealer LED fluid bloody rip off that, much cheaper online. |
