![]() | Home > Faults & Fixes (L663) > A/C fan speed fluctuating |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3316 ![]() ![]() |
The fan will change speed in order to maintain temperature.
Mine will start at a high speed and then the fan speed varies depending on temperature. Have you tried the manual setting (Try this...Air distribution to footwell and screen, ventilation fan on 2 or 3 and A/C on) Does the fan speed change or is it steady? |
Ckeller Member Since: 04 Oct 2023 Location: AZ Posts: 3 ![]() ![]() |
Hi Lightning, thank you for the reply. I will try those settings, I have only made adjustments on the push button A/C setting in the gear shift cluster. I have not tried any setting in the touch screen yet.
Currently the fan speed is random but let me try that out. Thanks again, Chris |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1448 ![]() ![]() ![]() |
The fan speed will fluctuate because you will have it set on auto climate control, so the fans will increase or decrease to keep the temperature at the temp you have selected
![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1472 ![]() ![]() |
Posted in wrong thread.
holtenc Member Since: 15 Aug 2023 Location: TX Posts: 28 ![]() ![]() |
I believe mine is doing the same thing as yours. The fan speed will randomly change for about a second or two and then go back to where it was. No idea why. It doesn't bother me, though I did think it was kind of odd. 2023 130 dynamic X. 4 zone climate
Thanks for the input everyone. I went to the extent of purchasing an anemometer to measure the air speed fluctuations and included a video below on a typical 100 degree day in AZ (sweater weather) haha. I can understand the idea of climate control in the vehicle and the system adjusting for ideal temp but this just doesn't feel right. In the heat of our summer in 115 temps the the air was still fluctuating to the point where it was uncomfortable in the car even with cooled seats.
https://www.dropbox.com/scl/fi/r5jdi9x3ubp...b&dl=0 |
