![]() | Home > My Defender > My 110 XS USW "Winnie" |
Super bit of DIY spray painting and maintenance
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11012 ![]() ![]() |
That is good news and it should be a bit better again once you have done the rear one
Ambo_Chris Member Since: 01 Dec 2021 Location: South West Posts: 32 ![]() ![]() ![]() |
Had a delivery from Paddocks…
![]() Click image to enlarge 2013 Baltic Blue 110 Utility Station Wagon XS 2.2 2000 Beige Discovery 2 Td5 GS (Long gone) 1994 Red (various) 90 300tdi CSW (Long gone) |
I think the wolfs look much better than the tired SVX alloys!
![]() Click image to enlarge ![]() Click image to enlarge 2013 Baltic Blue 110 Utility Station Wagon XS 2.2 2000 Beige Discovery 2 Td5 GS (Long gone) 1994 Red (various) 90 300tdi CSW (Long gone) |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1244 ![]() ![]() |
A good look. I went black in the end for mine.
![]() Click image to enlargewolf2black by Richard Holmes, on Flickr 1984 One-Ten CSW 2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2266 ![]() ![]() ![]() |
That does look nice 👍 |
They do look nice but the white lettering spoils it ( imo )
So I've managed to fit in a few jobs over the new year, working through the list from the garage.
First up was the leaking aircon condenser. I got one of the larger non-genuine replacement condensers from eBay (seller was Premier Supply) for £125 delivered. https://www.ebay.co.uk/str/premiersupplyuk...media=COPY and a 350mm Spal Fan, (VA08-AP10/C-23S, 12v Push) for £85. All in, a very easy job. Ony took about an hour. I made some T shaped fixings to fit the fan using some stainless bolts copying the SPAL fitting kit, but for a fraction of the price. I'll get the system regassed when it goes in to have the rear diff replaced. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 2013 Baltic Blue 110 Utility Station Wagon XS 2.2 2000 Beige Discovery 2 Td5 GS (Long gone) 1994 Red (various) 90 300tdi CSW (Long gone) |
Next was a repair to the top of the driver's door where it has cracked by the door lock mechanism. The loose trim and rattling window was starting to become a right pain!
![]() Click image to enlarge I cut out the top piece, then tidied up the edges and pained with primer. The new piece fitted fine with no trimming and as I don't have access to a welder, I riveted it in place after a coat of paint. unfortunately I've run out of the body colour I used for the hinges, so its jut primer for now. ![]() Click image to enlarge ![]() Click image to enlarge 2013 Baltic Blue 110 Utility Station Wagon XS 2.2 2000 Beige Discovery 2 Td5 GS (Long gone) 1994 Red (various) 90 300tdi CSW (Long gone) |
The Driver's seat back bolster had completely collapsed, making even the shortest drive pretty uncomfy so I took advantage of Exmoor trims 10% off deal before Christmas and got a two seat retrim kit with some new seat heaters. Took about 3 hours with the base being the most fiddly!
Just the passenger one to do now! ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 2013 Baltic Blue 110 Utility Station Wagon XS 2.2 2000 Beige Discovery 2 Td5 GS (Long gone) 1994 Red (various) 90 300tdi CSW (Long gone) |
Thank you for the update with the pic's and a few more jobs ticked off the list
Passenger side completed now too. Really smartens up the interior!
A couple of small electrical jobs today; fitted an extra USB socket by the passenger grab handle as the LR one always seems to be in the way. I used one of MUD UKs piggyback looms for the moment as I don't plan on using the original one. I also fitted a Vellerman 12v battery indicator light in the vacant button blank on the dash so I can keep an eye on the batttery charging. link here: http://www.velleman.co.uk/contents/en-uk/p114.html. it comes on with the ignition, then gives a slow flash whilst charging, then indicates red if battery low or overcharging. I saw someone else on here had done this mod, can't remember who to credit!
In an effort to try and stop the water ingress, the stars aligned and I have a few dry days off work. I replaced the rear body capping to side panel seals with new ones from YRM as it was leaking on one side through this joint:
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Whilst I was at it, I replaced the gaskets and bolts on the windscreen hinge blocks too. 2013 Baltic Blue 110 Utility Station Wagon XS 2.2 2000 Beige Discovery 2 Td5 GS (Long gone) 1994 Red (various) 90 300tdi CSW (Long gone) |
