Home > Puma (Tdci) > Reversing Light query
Staftly
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
Hi there, MOT time and no reversing light, its a 2012 XS UTE. I can fix most things mechanical but my knowledge of electrics is very basic so please bear with me. Checked fuses, bulbs and switched the bulb carrier with the fog light etc. Out with the multimeter. Tested for voltage at the fuse and I get 11.6v when earthed. Ignition on and in reverse and I get 11.3V at the rear bulb holder (which disappears when reverse disengaged). I have also checked the negative wire at the rear holder for continuity and I get continuity when ignition on and reverse engaged AND ALSO when reverse is not engaged. According to my limited knowledge of electrics it seems to check out ok, but still no light.
One very strange observation, when I connect a short piece of wire bewteen the positive connection at the rear holder (ignition on and in reverse) and earth the bulb to a good point, the bulb fails to light. When I do exactly the same at the fusebox end the bulb lights up!
Like I said, I dont do electrics as a rule but it seems to me that I have the voltage and negative continuity at the rear bulb holder but still no reverse light. I also asked a friend to conduct his own test without my interference and he basically arrived at the same decision. Im out of ideas, I'm hoping someone else has observed similar behaviour before. Thanks in advance for any suggestions.
Steve
Post #1008966 26th Sep 2023 3:28pm
LR Nuts
Rusty earth terminal at bulb location ?
Post #1008977 26th Sep 2023 4:12pm
Martin
Site Admin
https://www.defender2.net/forum/post574975.html#574975
Other things to check:
Swap the reverse light over with the fog (as complete assembly) - if it still doesn't work, it's not the bulb or the holder.
If you can get to the reverse switch plug, remove it and bridge it temporarily to check the lamp comes on. If it comes on, the switch is faulty.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1008979 26th Sep 2023 4:19pm
A fairly common problem with the MT82 is that the reverse switch isn't screwed fully home in the gearbox, or wear results in the button on the end of the switch not being pushed far enough into the switch to operate the light.
Post #1008983 26th Sep 2023 4:23pm
I'd suggest reverse light switch, too. You can see how I changed mine here:
https://www.defender2.net/forum/post733726.html#733726 Darren
Post #1008996 26th Sep 2023 5:18pm
Staftly
Hi all
Thanks for the suggestions. My next port of call was gong to be the gearbox switch. I particularly like the suggestion of bridging the terminals as a test. Right, cubby box out and lets take a look.
Really appreciate the suggestions, I'll let you know what I find.
Cheers Steve
Post #1009001 26th Sep 2023 5:42pm
Staftly
Hi guys
Whipped off the cubby box and you can see the switch. Removed the plug and shorted out across the terminals and the reverse light comes on, great advice, thanks. Removing the switch is another matter, 40 min later with blooded knuckles and a lot of swearing and it's finally out. I had to resort to an old 7/8 shortened spanner to allow access. Anyway, will order a new one and fit next week, then I can arrange an MOT.
Thanks all for your suggestions, much appreciated. Steve
Post #1009497 30th Sep 2023 2:06pm
I don't think the reversing light is part of the test, is it?
Post #1009498 30th Sep 2023 2:10pm
Staftly
Yup it is. I thought it wasnt myself but it's here on gov.uk
https://www.gov.uk/guidance/mot-inspection...-equipment
Post #1009506 30th Sep 2023 3:57pm
BrickBox
I was about to say 2009 onwards a reverse light is a requirement. 2017 5.0 V8 Supercharged RRS SVR
2008 2.4 110 Utility Station Wagon XS.
Post #1009513 30th Sep 2023 4:33pm
Everyday a school day, thanks.
Post #1009516 30th Sep 2023 4:46pm
Dinnu
Have you tried plugging the switch back, but still off the gearbox and pressing the ball and see if the light comes on? If it comes on, then probably some wear is preventing the ball to push the contacts together. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1009526 30th Sep 2023 6:07pm
Staftly
Hi Dinnu
Yes, the switch did actually work when tested on the bench so it was indeed wear and tear. I gently took about 1mm from the face of the bolt assembly using a 2x72 belt grinder, refitted and it's all good (for now at least). I'll get a new one ordered and can fit this slow time.
Steve
Post #1009697 2nd Oct 2023 8:11am
