Home > Technical > Replacement EGR Cooler needed
What EGR cooler should I buy?
Wait for original part at £363
50%
 50%  [1]
Buy cheaper OEM - Britpart £265 or Allmakes at £270
0%
 0%  [0]
Buy even cheaper replacement parts - Britpart £145; Allmakes £155
50%
 50%  [1]
Total Votes: 2
datcullen
2015 Defender 110 Puma 2.2 USW Java Black
Hi all,
Help / thoughts needed please.
I've done just over 100k in my 2015 2.2 TDCI. EGR cooler is leaking and indi garage are saying they are on back order from LR. What should I do:
1. Wait for original part at £363
2. Buy cheaper OEM - Britpart £265 or Allmakes at £270
3. Buy even cheaper replacement parts - Britpart £145; Allmakes £155
I'm unclear what the difference in reality is likely to be between the three - particularly the OEM and pattern parts from same manufacturer...?
All prices are from LR Direct and include VAT - https://www.lrdirect.com/lr049203-cooler-egr
All thoughts / poll submissions gratefully received.
TIA
Beau 110 UW - '15 2.2
90 - '85 V8 soft-top
RRC - '84 5 door, Option Pack C, 33k miles from new
Elise S1 - '00 Millennium SE
Elan +2 - '68 kit built by my dad
Panda 4x4 - '87 in Italy
Post #1009359 29th Sep 2023 10:23am
BrickBox
Buy the cheapest and get it remapped out. 2017 5.0 V8 Supercharged RRS SVR
2008 2.4 110 Utility Station Wagon XS.
Post #1009364 29th Sep 2023 12:59pm
datcullen
I had wondered about that as an option. Are there any downsides to remapping a 100k engine? 110 UW - '15 2.2
Post #1009365 29th Sep 2023 1:09pm
The only downside is that you'll wish you'd done it earlier. It's never too late to remap!
Post #1009370 29th Sep 2023 1:49pm
Ianh
It’s a standard ford part so I would check out the price and availability for a genuine ford one first. The ford part numbers will be on it.
As yours is a 2.2 I believe mapping out and blanking EGR / EGR cooler also requires mapping out the DPF and DPF removal. That’s something you need to check is correct as replacing the DPF downpipe with a convincing DPF downpipe shell is also costly but will need doing to pass MOT visual inspection.
Post #1009376 29th Sep 2023 2:27pm
datcullen
Thanks Ian - good point which I'll double check. 110 UW - '15 2.2
Post #1009383 29th Sep 2023 3:30pm
