Home > Puma (Tdci) > Head gasket repair Surrey/Hampshire
Yesjus
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Santorini Black
Hi,
After lots of problems with overheating it appears to be the head gasket 😩
Anyone know of any places local to the Surrey/Hampshire area that they would recommend and are reasonable?
Thanks
Post #1009020 26th Sep 2023 5:43pm
Welshsurferdude
Wales
Brooklyn 4x4 are a good one, I used them in my uni days at Southampton many years ago in 2002 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS
Post #1009021 26th Sep 2023 5:46pm
Yesjus
Thanks, after some reading some suggest it’s better to just replace the engine rather than head repair due to costs involved in repair??
Mine is at 120k so it might be a better option as it would be the time to have timing chain replaced also! Any thoughts?
Post #1009029 26th Sep 2023 6:28pm
NickMc
Depends if it’s just the gasket blown. Avoid the cheapo aftermarket engine parts and rebuild kits the quality leaves a lot to be desired. Oversized pistons and non standard bearings are available for these engines.
Turner Engineering are about the best to deal with for LR engine parts.
Post #1009036 26th Sep 2023 6:52pm
cd110
United Kingdom 2013 Defender 110 Puma 2.2 USW Corris Grey
I used Safari Engineering in Eversley for a service and some other bits and pieces and they did a great job. Really seem to know their stuff.
Post #1009067 26th Sep 2023 9:51pm
MK
If oil pressure, compression are within specs and valve train wear look like 120kkm I do not see why you want to get a new engine. And I would first check as well the egr cooler.
As mentioned in the forum sometimes head failure has been misdiagnosed. Puma 110" SW
Post #1009118 27th Sep 2023 11:03am
Yesjus
The only reason im thinking new (when I say new I mean a recon engine) is because of the cost.
Initial estimates for HG repair including new timing chain are around £3500.
A recon engine (albeit from eBay!) are around £1600, so trying to work out if labour costs on engine swap as more straight forward would be worth it.
Post #1009156 27th Sep 2023 5:36pm
MK
Well, I do not know but hopefully guys from this forum should be able to advice you if a recon engine is the way to go. I find it scary unless an engine is provided by a reputable shop. Puma 110" SW
Post #1009158 27th Sep 2023 5:45pm
Yesjus
This is the company if anyone has used before?
http://engine-swap.com
Post #1009162 27th Sep 2023 6:00pm
Ianh
I would check out ford transit engine repair specialists and get a quote for the work from them. I expect it will be significantly less then the £3.5k you have been quoted.
Post #1009176 27th Sep 2023 7:10pm
NickMc
Be careful as I’ve said of “recon” engines with cheap pattern parts.
Post #1009180 27th Sep 2023 7:23pm
