Home > Td5 > Sudden drop in fuel mileage
charcoal
United Kingdom 2005 Defender 110 Td5 HT Bonatti Grey
Usually I would get 30-31mpg from the Defender which is mostly motorway and A road driving on the commute to work. Recently that has dropped suddenly to 28 last time I calculated and seems to be even lower now, I haven't yet filled up to work it out but where I would once get 450-470 miles from a tank I'm now sitting at about 400 with the low fuel light now illuminated. The only things I've changed are installed cruise control and adding half a litre of engine oil as it was a little low. Surely using cruise control should do the exact opposite of this? Mad 1999 Land Rover Defender 110 td5 station wagon
1998 Land Rover Defender 110 County Station Wagon ~ Sold
1995 Land Rover Defender 110 V8 Station Wagon ~ Sold Sad
1985 Land Rover 110 ex mod project Tithonus ~ Sold Sad
Post #1008620 23rd Sep 2023 9:44pm
landy andy
Check your fuel pressure regulator on the cylinder head. Often leak.
Post #1008623 23rd Sep 2023 9:48pm
charcoal
Thanks will take a look tomorrow, is this something that has to be replaced outright when leaking or will a new gasket suffice? 1999 Land Rover Defender 110 td5 station wagon
Post #1008626 23rd Sep 2023 9:59pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Most likely the weather.
Unless there is a pool of fuel underneath or the oil level is increasing (injector seals or cracked head) I would not worry.
My golf GTD has also lost MPG since yhe recent hot weather.
Post #1008636 24th Sep 2023 12:13am
charcoal
Are you sure? I have been driving it daily throughout the hot weather and its still been returning 30mpg up until the week before last 1999 Land Rover Defender 110 td5 station wagon
Post #1008672 24th Sep 2023 12:42pm
markb110
Shrinkflation…….they’re probably mixing it with water….. Whistle
Post #1008680 24th Sep 2023 1:19pm
Check the MAF sensor as well, especially if you've noticed that performance has dropped off a little.
Post #1008702 24th Sep 2023 5:39pm
Steve B
No not sure, an observation after driving diesels. The weather has cooled off a little especially in the mornings.
Try not using the cruise control and see If the mpg recovers, I think you can drive better without it.
Post #1008781 25th Sep 2023 10:42am
charcoal
I gone through a few of the points made here, MAP sensor was a little oily so cleaned that, tried driving with MAF plugged in and unplugged and felt no difference in performance with either of these. Fuel pressure regulator doesn't appear to be leaking. I did notice however that the egr valve actuator is absolutely caked in filth, maybe if this is no longer working correctly it's contributing to the loss of mileage? 1999 Land Rover Defender 110 td5 station wagon
Post #1009290 28th Sep 2023 5:47pm
Hazza
United Kingdom 1990 Defender 110 Td5 HT Bronze Green
If you don't notice any difference with MAF plugged in or unplugged I'd suggest getting it replaced with a VDO or Siemens one (or better, find someone with a nanocom to test it with). 1990 Defender 110 200TDI Camper - now converted to Td5 power
Post #1009317 28th Sep 2023 8:52pm
