![]() | Home > Maintenance & Modifications > Hub seal gone? |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2382 ![]() ![]() ![]() |
Shouldn't be a problem at 65nm.
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2274 ![]() ![]() ![]() |
If only Dr Frankenstein had done the same. His monster would have been much less scary 🤪 |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3600 ![]() ![]() ![]() |
Hence I say ‘loosening’ in case they seize up. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Fitted properly there is no reason why they should seize. The only ones I have encountered which have seized have done so because the hole has been filled with thread lock and gasket compound, neither of which are necessary. Even if using genuine preloaded bolts and genuine gaskets and fitting them correctly, they are extremely unlikely to seize.
If they do you can have the delightful learning experience of drilling them out with a left-hand drill ! ![]() |
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553 ![]() ![]() ![]() |
My question regarding longevity is more thinking if the internal faces of the socket head suffer from corrosion and affect using an allen key. Obviously cleaning up a rusty hex head is a case of using a wire brush where that would be more difficult with a cap head. |
Van Diesel Member Since: 12 Oct 2013 Location: Suffolk Posts: 177 ![]() ![]() ![]() |
Thanks for the advice. It has had new wheels recently but I had noticed some evidence of oil/grease on the old wheels.
I'll clean it up and tighten the bolts. Whats suggested nm for these? |
I've never had a problem with SHC, but I usually put a blob of grease in the socket, or paint them.
Thanks @ I like old skool for your suggestion.
Checked the flange bolts today and some were indeed loose. One side looser than other, which had more oil streaks on so made sense. Cleaned up and test drove, spotless on return, so thanks for that tip. ![]() |
