![]() | Home > Puma (Tdci) > Light guard or not? |
Shropshirelad Member Since: 28 Aug 2023 Location: Shresbury Posts: 20 ![]() ![]() ![]() |
Thoughts
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 981 ![]() ![]() ![]() |
I think that it depends on what else you have fitted e.g. raised air intake, side window grills, exped roof rack, side light protectors etc.
Personally I'm not a great fan of of them and don't think that they offer that much protection but it all depends on the look you are wanting to achieve for your defender. Jim |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3588 ![]() ![]() ![]() |
There are also aftermarket front light guards that screw through the headlamp finisher. At least if you want to remove them, just replace the finisher, and the holes will not be visible. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2672 ![]() ![]() ![]() |
If you have standard halogen bulbs and drive through wet muddy puddles (Salisbury Plain for example), the mud will bake to the lenses.
With guards it makes it harder to clean the lights. |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 861 ![]() ![]() ![]() |
I'm not the biggest fan of the air-con grille... Light gaurds just make the front look a little more integrated
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5982 ![]() ![]() |
Cleaning the headlights, or just the front is a complete PITA with them fitted.
Spruce Pirate Member Since: 08 Feb 2013 Location: Stirlingshire Posts: 124 ![]() ![]() ![]() |
I like them on the rear, can save a lens if you're manoeuvring in tight spots. Never had them on the front, the bumper sticks out and you'll hit something with that first before doing a light. Dirty Deeds - Done Dirt Cheap
Timcat Member Since: 20 Jul 2016 Location: Rugby at the moment Posts: 1025 ![]() ![]() ![]() |
We have them on Henry the 110, as said it’s a pain to clean the headlights but also protects our Nolden gen 2 headlights from rocks / branches & birds here in Africa.
