![]() | Home > In Car Electronics > Pre Made Loom’s Into One Switch |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3640 ![]() ![]() ![]() |
Did something similar with a kit/loom for a compressor switch and 2 diff lockers. The kit came with carling switches, but we wanted the LandRover push button switches. It took some thinking, and internal modifications to the switches (I think I needed to change from normally open to normally closed, although not clear in my mind anymore), and also the supply to the switch LED. But for sure it is possible. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6722 ![]() ![]() ![]() |
How do you want the lights to be switched? Only off the dash switch or with the headlights, or choice of both, etc?
Which looms are they, any link to what you bought? ![]() ![]() |
StressedComa Member Since: 23 Jul 2022 Location: Wakefield Posts: 72 ![]() ![]() |
Hi,
These are what I’ve bought, one spot kit and one flood kit: https://myhellalights.com/product/black-ma...-3-2-spot/ I’m happy just to have them switched on their own and not with the full beam headlights. Each switch has three wires going into the back of it so guess +/- and then earth or to light the switch when turned on? I’d happily, and have space, on the dash side cheek panel from the double din conversion to put two of these switches from MUD where I can use the already fitted spades onto the switch and then find a supply to illuminate when the headlights are turned on? https://www.mudstuff.co.uk/products/mud-de...ront-light Wiring isn’t my strong point so would like to keep it simple but also keep it looking relatively OEM. |
