Home > Puma (Tdci) > Mystery Loose Hose
JackLongley
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Mystery Loose Hose
Hi all,
Returning to the collective hive mind of Defender2 to help me identify a mystery loose hose.
Currently in the middle of diagnosing an overheating issue we experienced last weekend (cruising at 70, around 30-32degrees outside, all of a sudden a complete loss of power for 5 or so seconds, with the temp gauge going up to around 3/4, then a return to normal - repeated three times over the journey) - lots of solutions well documented on here so working my way through.
Anyway, whilst doing a RELD test to rule out the head gasket - I noticed this loose hose just below the heater valve (images attached) can't say I have ever noticed it before and I was hoping someone would be able to tell me what it is, and where it's come from (if it has come from anywhere). Its around a 6mm OD hose (didn't have my vernier to hand for an exact measure), with a 180degree curve in the end.
Thanks all in advance! 2007, 110 Puma 2.4, Tonga Green, "Leonard"
Post #1007747 15th Sep 2023 7:30pm
No photos attached, no photos in your gallery.... Big Cry
However from you description it will either be the LT230 breather or the front axle breather. Very Happy
Post #1007749 15th Sep 2023 7:37pm
JackLongley
Apologies! Still a newbie here Rolling Eyes
Hopefully this'll work....
Post #1007751 15th Sep 2023 7:41pm
htb2
Wales
Breather hose, supposed to be open that end.
Post #1007753 15th Sep 2023 7:49pm
JackLongley
Thanks! Is that usual placement for it, or has it come loose from a fitting somewhere? 2007, 110 Puma 2.4, Tonga Green, "Leonard"
Post #1007754 15th Sep 2023 7:50pm
swt
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
That's how they come from factory. Wading kits, such as those from Nugget Stuff, often have a more sophisticated termination!
Post #1007757 15th Sep 2023 7:58pm
That's normal, they seem to be an afterthought! However the two that come up there are in a less stupid place than the one for the rear axle.
Post #1007760 15th Sep 2023 8:21pm
