![]() | Home > Puma (Tdci) > 2010 Puma 90 clunk when changing gears |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 823 ![]() ![]() |
hi, you don't make any mention of the front pipe... I had to remove mine anyway ,but im curious to know whether the box can be dropped with it in place on the 2.2.. the manuals ive read all talk about removing it to do the clutch |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge I'll add a few photos of the bits and bobs I did👍 ![]() Click image to enlarge |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17944 ![]() ![]() ![]() |
If you search the forum you will find that the official workshop manual is available for download, and that will be your best bet. There is nothing particularly difficult about the job (it really is just basic spannering) but there is quite a lot to do.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3614 ![]() ![]() ![]() |
On this forum there are also a lot of threads on how to remove the transfer box only and the gearbox, with a lot of tips and tricks and things to watch out for. Example: using long studs to help install the transfer case back to adaptor housing.
On the topic of installing the TC back on, very important thing to note is that not all bolts are of equal length, and putting a long bolt in the wrong place will bind the intermediate gears. I have opted to replace these bolts with studs, glued and screwed to the correct depth in the transfer case. Make sure you have a good quality and hefty puller to pull the adaptor female spline cup from the gearbox to replace the adapter shaft assembly. I know that the Ford manual calls for very high tightening torque for the female spline cup bolt, then back off and re tighten to the correct spec. This is to ensure that the cup has seated all the way on the mainshaft splines as they are interference fit. But probably you cannot do that with a LOF output shaft, so should follow the LOF installation procedure. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
its still fairly fresh in my mind and you will see from above posts that I dropped the two boxes out using a crane, but installed them individually because combined they are just to heavy.. most points have been made , but I mentioned it above and im still unclear about the answer, so ill mention it again...if you have the 2.2l with dpf, and the front pipe has to be removed to drop the gearbox, then there is even more work involved, as the only way the dpf can be removed is to raise the engine and getting to the engine mounts is a pain involving even more bits requiring removal. it has been suggested it may be possible to drop the box without removing the front pipe but not had a definitive answer on that yet..the manual suggests you do need to , and because I was changing the exhaust anyway I did remove the front pipe.. good luck anyway |
