![]() | Home > Maintenance & Modifications > Steering damper |
Daysleepers Member Since: 15 Dec 2022 Location: Suffolk Posts: 111 ![]() ![]() ![]() |
Sorry, not answering your question. But I was considering swapping my standard damper for the one you’re taking off. Hoping it might settle it on the motorway?
What are you reasons for changing? |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2291 ![]() ![]() ![]() |
Yes indeed ![]() |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5998 ![]() ![]() |
Yes straight swap back.
If you are fitting one to improve things then you have issues that you are trying to cover up. |
Van Diesel Member Since: 12 Oct 2013 Location: Suffolk Posts: 177 ![]() ![]() ![]() |
No, it drives absolutely fine but it's just undergone a big restoration to a heritage look and I don't feel this looks right so wanted something standard looking.
Is there a noticeable difference between a standard damper and one like this? ![]() Click image to enlarge |
That looks great!
If yours is in good condition give me a shout when you have it off and I’ll probably take it off your hands! |
Thanks
Ok, will do ![]() |
Might possibly take them too!
We are both Suffolk too. |
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 921 ![]() ![]() |
Sounds like you might have something worn/broken or not right. A Defender should be perfectly stable at motorway speeds. |
I really meant a slightly firmer feel to the steering, more centred rather than stable.
But changing some bushes next week anyway! |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2685 ![]() ![]() ![]() |
Just a personal point of view. I tried that type of dampener and ended up taking it back off. The reason was that the spring kept unwinding from the block then the steering was being pushed over to one side. I would reset the spring, only for it to do the same when I was driving. If you look at the picture, that spring is held in place by a jubilee clip, so I suspect they had the same problem as I. I am currently using an Old Man Emu dampener, fit and forget. |
It could be worn bushes. But do remember a Land Rover has a steering box, the axles are isolated from the chassis via 4 rubber bushes and the tyres are high profile. The steering will feel different to a car or even a modern unibody Land Rover with rack & pinion steering. |
Bowbearer Member Since: 12 Aug 2022 Location: Norfolk Posts: 229 ![]() ![]() ![]() |
I had same problem as Mark b
At first it was fine but then the spring started slipping Created a bit of a wobble at speed. Changed the usual but still doing it until I put a heavy duty damper on. All good now. My 110 has a Salisbury front axel so is all heavy duty. If I was you I’d change it to look more original, nice job on the truck. |
I think replacement with an OEM makes sense - they are perfectly adequate.
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 577 ![]() ![]() ![]() |
A question for Mark B. How does the OME damper help, when compared to the standard one. Mines fine, but I'm not sure exactly what they're ( upgraded types ) supposed to do, apart from mask other problems. Thanks.
