![]() | Home > Maintenance & Modifications > Front seat box centre panel clips |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3614 ![]() ![]() ![]() |
See #6
https://www.lrworkshop.com/diagrams/land-r...gs_52756#6 Thats what my 1988 has. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
Yup, 4-off metal push in clips as above.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6030 ![]() ![]() ![]() |
Cheers both. These clips push into the round holes in the main seat base section? i.e not the top lid (item 1) 1999 Defender TD5 110
Yes, they push into the holes in the seatbox. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
It would be worth getting some 2mm closed cell foam strip to replace the stuff on the lid. They usually get very flat and let cold/heat in/out.
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1329 ![]() ![]() ![]() |
Quite an elegant design too! The screw locks the clip firmly inside the square hole. Also not Plastic, Plastic is never the most elegant solution given time.. |
The hole in the seatbox is actually not a round hole, but looked like there’s a superimposed square hole. Unless the latter was created by vibration over the many years the clips were installed. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
I have added foam strip around the lid already ![]() Regards John M0VAZ Econet Station 48 no clock |
I will double check but mine do look round. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Also adding some 5mm foam between the metal plate and the base of the cubby, for two reasons
1. I discovered an annoying squeak as two bolts for the cubby are missing(my bad) which was when I noticed a lack of fixings apart from the two at front by the ECU diagnostic socket/mounting bracket 2. To add some more noise deadening. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
