![]() | Home > Puma (Tdci) > Shocks |
| fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626
How do you find the bilsteins ?
I have them and find them great |
| defender75 Member Since: 06 Nov 2010 Location: Germany Posts: 219
Over rough stuff they are much better than stock but on flat smooth roads the truck is still a bit bouncy. Did you change your springs?
Yes i put Discovery H'D springs on as well....i find the ride much better
disco hd springs fit?
I guess the truck comes standard with hd springs? |
My truck is lhd and the front drivers side shock has a white stripe. Passenger side has a yellow.
Rear I don't see a stripe. Anyone have a clue what my 09 truck has. I just want a nice ride on the road. Truck is stock with a g4 rack and used on road 99.999999 percent of the time. |
| wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581
You've got the standard LR front springs for the 110 LHD on the front - NRC8044 (Driver, White, Front) and the NRC8045 (Passenger, Yellow, Front).
Rear you could have the helper coil spring inserted inside the main road spring? White/Green, Brown/Purple??? Make sure your tyre pressures are OK before throwing money at a possible solution. 30/38psi works well usually. |
I don't see any helper springs inside. Running 30 in the front and 35 in the back.
265/75/16 km2s |
| fishrider Member Since: 01 Dec 2010 Location: Cornwall Posts: 79
I too am looking to change my springs for more compliant ones to give a better ride on the road. I swear badly maintained tarmac is worse than a good gravel dirt road. The roads are so bumpy compared with 5 years ago.
Tried looking into it but the only things that come up are performance springs for turning the Landy into a performance racer or HD springs for over landing under a full load. Would be great to hear about ones that are rated for carrying passengers only. Mines a stock 110 SW 2010 110 HT TD5 - 110 XS SW Puma |
| bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189
my came with HD springs on the rear and had a very hard bouncy ride, don't often carry any real weight or tow so i changed them for standard LR road springs and put on qood quality shocks all round. made a huge difference. BM52
YOu didn't change the front springs? Just the back? Didn't the truck sag?
My truck si a 110 sw if that matters. |
just the rear, all level and fine - no issues just a smoother ride. BM52
I'm surprised the 90 comes with HD springs . Is that anything to do with it being XS spec ?
Mines 110 XS SW haven't checked but assumed it was on standard springs 110 HT TD5 - 110 XS SW Puma |
If you are considering the change, you could do a lot worse than a Terrafirma kit.
You have to option of light/medium/heavy springs and can either use the gas dampers, or the big bore oil filled units. They are good value and high quality, and you can mix them, so light front and medium rear. |
| BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253
Terrafirma kit is poor quality (in my opinion). I sent shocks back to them after bushes went in less than 2000 miles. shocks were so hard there is no way the bushes could have survived.
The very best set up I've ever had was OME shocks and Iron Man "B" springs. magic on the road, fabulous offroad. If I was having another 90 I'd go all Iron Man. |
