![]() | Home > Puma (Tdci) > Puma Rad Arrangement |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3600 ![]() ![]() ![]() |
The cross braces are sided, and I am suspecting that yours might have been fitted the wrong way around (left on right and vice versa). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
the_lincs_landies Member Since: 29 May 2023 Location: Boston, Lincs Posts: 230 ![]() ![]() |
Thanks Dinnu!
Could they be upside down as well as the wrong way around too? I need to have a proper look tbh, but are there markings for L/R Top/Bottom so I can be sure? |
They cannot be mounted up side down. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
I do not believe there is any marking unless they are new and could still have a label.
See items 5 and 6 for a clear understanding in the LRWorkshop link. https://www.lrworkshop.com/diagrams/land-r...se_44831#6 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Thanks Dinnu, I'll have a look after work and see if they sit closer if i take them out and swap them around!
If that is the issue, that's a nice simple fix, then the next thing is working out why the headlight surrounds don't align on the 2 screws by the grille when they align with the indicators/sidelights (or vice versa) |
Take a good picture of how the crossbars are fitted after removing the grille before further disassembly. IIRC, was a bit tricky to get it re aligned with the bonnet pin as the lock spring is quite strong. I do not remember if you can fit the lock spring afterwards or not. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Thanks Dinnu, hadnt thought about added complexities of springs and suchlike
