Home > Tdi > TDI 200 Year 1991 Oil Cooler Pipe |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3240 |
I think I have a spare set of oil cooler pipes, will have to check how the seal is in the engine side. I am very sure its a taper seal in the radiator side. But memory is a bit hazy on how the sealing is on the engine side. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
17th Aug 2023 4:24pm |
cykoh85 Member Since: 25 Apr 2022 Location: Selangor Posts: 113 |
Oh I see, Do you still intend to use it? It also has a taper seal on the engine side, but I believe it doesn't come with an O-ring (as earlier models don't have O-ring, correct?).
17th Aug 2023 4:38pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2105 |
Correct. Very late 200 tdi had o rings but most are taper.
Mo The Land Rover 90 - Many are called, few are chosen. |
17th Aug 2023 6:59pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1572 |
Have you got the pipe support clip fitted? I would try some loctite thread sealer like 561 or 545 instead of ptfe tape, check locally though as what suits.
17th Aug 2023 7:54pm |
Yes, I think mine don't have the O-ring. |
18th Aug 2023 7:36am |
No, so must have the pipe support clip? I think have to change a new pipe for better solution. and thanks for your recommendation - loctite thread sealer, able to buy it here. thank you. |
18th Aug 2023 7:37am |
Dear all,
Update: I noticed there is a leak even after I opened it and refitted it using PTFE tape. It appears that I really need to replace the oil cooler pipe for a better solution. One more notice: Does anyone know what this thing is (circled in red)? I also noticed some leaks at the bottom (circled in blue). Is there any gasket there? Please refer to the attached picture. Click image to enlarge thank you. |
2nd Sep 2023 2:01pm |
That is the brake vacuum pump. Yes, there is normally a gasket underneath it. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
2nd Sep 2023 3:39pm |
Alright, if I open it, will any fluids like brake fluid come out? Because I've noticed that the leak underneath is engine oil.
Thank you Dinnu |
3rd Sep 2023 4:45am |
No, no brake fluid. Just undo the 3 hex head bolts, and lift up. If now remember correctly there may be 2 gaskets, as the bracket for the throttle linkage is sandwiched between the vacuum pump and the engine block. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
3rd Sep 2023 4:52am |
Ok Dinnu.
As picture below, right? Can I DIY the engine block gasket using a paper gasket? Appreciated your helps! |
3rd Sep 2023 5:47am |
Yes and yes. I like to use fibre type of gasket when I need a diy approach. For this application, thickness is not so critical, but do not go too thick as would ‘warp’ the vacuum pump.
For extra measure, I do sometimes smear a small amount of RTV on both sides of the gasket. It also helps to locate the gasket, especially in this case as is a bit fiddly to align the bottom gasket, the throttle bracket, the top gasket and finally the vacuum pump, which shaft need to be in the correct position for the drive to engage all at the same time. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
3rd Sep 2023 6:05am |
Thank you, Dinnu. The information you provided is very knowledgeable. Well done.
3rd Sep 2023 2:22pm |
