Home > Td5 > Random plug
Evil Elsie
United Kingdom 2002 Defender 110 Td5 HT Alpine White
Random plug
Hello All,
This may be better in the 'leccy section but...
I've just removed my Cubby box and found an aftermarket rocker switch hanging around under there. I traced it back to an OE plug that exits the main loom above the Transfer box. From the loom it's 2 cores - 1 black and 1 that could be either white with a black stripe or black with a white stripe.
I was hoping that it might be an anti theft thing but the engine starts whichever way the switch is. Any ideas..??
Cheers, Dave 2002 Land Rover 110 Td5 Utility
1990 Suzuki GSXR 1100L
1980 Yamaha RD 350LC
1976 Yamaha RD 400C
Post #1006171 1st Sep 2023 4:05pm
Hazza
United Kingdom 1990 Defender 110 Td5 HT Bronze Green
White with a black stripe is High/Low wiring. There is meant to be a switch on the transfer box to control this but sounds like someone has bypassed it to a rocker on yours.
Switching it will affect how sensitive the throttle pedal is. 1990 Defender 110 200TDI Camper - now converted to Td5 power
Post #1006186 1st Sep 2023 5:42pm
Evil Elsie
Ah, that's interesting - thanks for the answer.
I wonder if it's because I have a Disco (1.2) T/box..??
I guess it dampens the throttle response I'm Low box..??
I'm going 'laning' in a couple of weeks so will experiment then..πŸ˜πŸ‘πŸ˜
Thanks again for your help. 2002 Land Rover 110 Td5 Utility
1976 Yamaha RD 400C
Post #1006189 1st Sep 2023 6:29pm
Hazza
Possibly the reason, although I think the D2 box should have the switch too, could be wrong though.
Yes, dampens throttle response.
You've reminded me that I need to wire mine in, I never connected it up after doing my td5 swap! 1990 Defender 110 200TDI Camper - now converted to Td5 power
Post #1006191 1st Sep 2023 6:51pm
Martin
Site Admin
It’s a manual override switch for the high/low detection.
A proper D2 box will have the switch. If a D1 box has been fitted, it won’t have the switch.
Either a previous owner liked the low range pedal response, or there’s no switch on the box so this has been put in as a workaround.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1006195 1st Sep 2023 7:19pm
Evil Elsie
That's good to know Gents - thanks for the replies.. πŸ‘πŸ˜πŸ‘
I imagine that it could also be helpful in snowy conditions...
Cheers. 2002 Land Rover 110 Td5 Utility
1976 Yamaha RD 400C
Post #1006213 1st Sep 2023 8:36pm
