Home > Maintenance & Modifications > clean galvanized chassis for painting
olistr
Germany
Hi,
I have a galv. chassis from Marsland that has been used for about 5 years. It is rather dirty and I tried to clean it with zink cleaner and abrasive bonded fabric. Of course the zink should stay.
Any suggestions how to clean it properly without damaging the zink too much?
I wanted to avoid blasting it to avoid the mess, and dry ice blasting is kinda expensive over here.
Post #1005874 30th Aug 2023 9:46am
geobloke
As your chassis is 5 years old it has aged and the galv surface has become "weathered", so do your best to remove as much of the grime with soapy water then when it is dry use a mordant solution to prep for paint.
This is the stuff I use on galv before paint and it works very well. https://www.frost.co.uk/granville-galvanis...XUEALw_wcB
The top coat I used on the second row crossmember was Raptor 1k undercoat rattler can. Super covering and it will be lanoguarded once fitted.
Post #1005878 30th Aug 2023 10:06am
olistr
Germany
Thx alot geobloke,
I planed on a 2k primer (RADEX EP Epoxy Primer) followed by PU 330-20 2K-PU, I guess that won't be an issue
Post #1005901 30th Aug 2023 12:53pm
geobloke
No issue with the 2k. I would plan to spray some chassis wax inside as well as an extra precaution, even zinc wears off eventually.
My original chassis has lasted 20 odd years and has only rusted through along the internal welds of all places and you cannot do a thing about that, but Big Cry
Post #1005912 30th Aug 2023 2:39pm
spudfan
Ireland
https://www.hammerite.co.uk/applications/direct-galvanised-paint/ 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #1005956 30th Aug 2023 8:59pm
spudfan
Ireland
Deleted...double post 1982 88" 2.25 diesel
Post #1005957 30th Aug 2023 8:59pm
NickMc
I see you’re in Ireland too, I’d recommend this stuff it’s not cheap, but then there’s no primer, etch or t-wash etc to buy and it’s one coat https://sperringalvanisers.com/galvacoat-galvanized-paint/
Post #1005963 30th Aug 2023 9:30pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
You won’t need the mordant on old galvanized steel. For cleaning, after a wash, use a good degreaser/panel wipe that will leave no residue.
If you want to be sure your primer will adhere to galv well, you can use an etch primer first. If you have experience of it and know that it will cope with off road abuse, then your epoxy primer straight onto to galv is ok.
Post #1005967 30th Aug 2023 9:51pm
olistr
Germany
Hi guys,
thx all for the feedback.
I have spoken with 3 local paint shops,
they all recommended 2k primer and then raptor like paint for the chassis.
they recommended not to use etch primer as it is 1k and counterproductive.
Since the chassis is really dirty, They recommended to use a zink cleaner although there is already natural oxidation.
I guess I need a good clean with something that removes all the oily/greasy bits first.
Post #1005976 31st Aug 2023 7:40am
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Raptor paint chips easily so I'd be cautious using it on a chassis. I use POR15 on chassis.
Post #1005991 31st Aug 2023 9:32am
olistr
Germany
It is actually not raptor, it is a 2k paint with a structure like raptor specially made for chassis and protection against stones etc..
Post #1005997 31st Aug 2023 10:11am
TexasRover
Interesting, can ask a question about that? I have a new galvanised bumper AND a bunch of these small pots of POR15 black paint. I love that paint, but I have been hesitant to use it on my new bumper straight as I am concerned it might flake off over time. I also don't have access to this mysterious T-wash Mordant Solution, which is a bit of a British thing, certainly not off the shelf in Mainland Europe.
Your experience with POR15 on galvanised steel without a primer is good? No signs of cracking and peeling? POR15 is pretty strong.
Post #1006009 31st Aug 2023 11:58am
olistr
Germany
Salutation de Kehl TexasRover,
If you have a new galv piece, you need to accelerate oxydation before painting it.
I was recomended https://www.lackstore.de/Mipa-Zinkreiniger-10-Liter
to do so.
Post #1006011 31st Aug 2023 12:30pm
geobloke
There is also Rustins galvanised metal primer via amazon.fr that would do the job.
[url]https://www.amazon.fr/Rustins-galvanisé-Primer-250-ml/dp/B07D4J6FTP/ref=sr_1_9?__mk_fr_FR=ÅMÅŽÕÑ&crid=277KPZVZR0AZT&keywords=rustins+apprêt+métallique&qid=1693482758&sprefix=rustins+apprêt+métallique%2Caps%2C110&sr=8-9[/url]
Post #1006016 31st Aug 2023 12:54pm
NickMc
I’ve tried that stuff before Geo, awful!
Post #1006056 31st Aug 2023 6:52pm
