![]() | Home > Puma (Tdci) > steering rattle |
ijomps Member Since: 06 Jun 2019 Location: graz Posts: 8 ![]() ![]() ![]() |
good morning folks,
my first thread here, so hopefully i am behaving correctly. sorry for my bad english as its not my mother tongue ![]() i love this forum as it helped me a lot in recent times, so thank you guys so much for sharing so much knowledge. hopefully you can help me out with some advice on this topic: i own an td4 90 HT and recognized a pretty unpleasant steering rattle when driving on unpaved roads and washed out lanes. its not the movement of the steering wheel that concerns me, its the rattling sound. is this something i should be concerned of? or is this just normal? or simply too much air in my tire? ![]() tire pressure might have been around 2 bar each which equals 29 psi. i uploaded a video of it here if you wanna look: https://youtube.com/shorts/yONkIVR6ugQ thanks in advance for any help and kind regards from rainy austria, christian |
thanks a lot al - will check it out
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1857 ![]() ![]() ![]() |
If your truck is left hand drive, you don’t need the heat shield so the td5 part is perfect!
Keith |
thanks guys for the hints and tips.
also found a tirsbaek.tv video where they have the exact same noise. exactly coming from the steering shaft joint you mentionend. thanks again. |
