Home > Modifications & Maintenance (L663) > BREMBO 6-Pot Brake Upgrade
Page 4 of 5 <12345>
mmbanf
Italy
Hello,
I confirm in 2021 when we originally bought 22-inch rims, the brakes were modified, 380 with six front pistons and 365 with two rear pistons.
Marco
Post #1005751 29th Aug 2023 2:53pm
mcma1
Post #1005775 29th Aug 2023 6:16pm
mcma1
Got these from the dealer today but does anyone know if a brake bleed and setup is straightforward on the L663?
 Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #1006220 1st Sep 2023 9:13pm
Linds Hanson
Usually not a problem so long as you keep the hoses clamped off and system full of fluid, just normal bleeding procedure Andy
Post #1006251 2nd Sep 2023 1:03pm
mcma1
Post #1006266 2nd Sep 2023 6:29pm
mmbanf
Italy
[quote="mcma1"]Got these from the dealer today but does anyone know if a brake bleed and setup is straightforward on the L663?
[/quote
hello, on the Defender it is a problem.....
you must first of all put the braking system , abs in service , using the gap tool or the Land Rover wizard, otherwise you will not purge anything and only errors......on the bcm.
secondly, an economic system would be recommended to put pressure on the system, without this the result is not guaranteed.
I'll give you a summary of the procedure.
Post #1006312 3rd Sep 2023 9:44am
mcma1
The method Linds described sounds much easier Big Cry Hoped myself and Mr Redman could do these some evening and avoid the main dealer. Andy
2014 Corris 110 SW
LS3 V8 build...
Post #1006332 3rd Sep 2023 12:55pm
mmbanf
Italy
the job is certainly not simple, this "manual" procedure should (I'm not sure) set the service mode, and give the possibility to bleed the brakes.
to apply pressure I use this economical tool.
I didn't understand one thing..... you already have six-piston brake calipers on your defender, are you replacing them just for the color?
Post #1006341 3rd Sep 2023 2:31pm
mcma1
Yes they look really poor un painted. It is just easier and quicker to swap them out. I will perhaps have the current 6 pots powder coated and sell them when removed. Andy
2014 Corris 110 SW
LS3 V8 build...
Post #1006344 3rd Sep 2023 2:37pm
mmbanf
Italy
ok, Thumbs Up
the six piston brake calipers contain a lot of oil, when you connect them, before bleeding, fill the oil tank, top it up, wait with the valves open without applying pressure and without the brake pedal until it starts to oil coming out of the valves.
Post #1006345 3rd Sep 2023 2:42pm
Steve34
Italy
Buongiorno Marco, io ho il defender 110 2024 200 cv con cerchi da 20 e pinze piccole, secondo te posso installare le pinze come le tue? Grazie
Post #1025044 17th Feb 2024 11:22pm
abyss
Australia
My car is P400S came with 365mm front brake disc and Brembo 4 pot calipers. I’m looking to upgrade to Brembo 6 pots 380mm.
Apart from new 380mm discs and pads. Do I need new hubs and new shims?
Post #1056278 4th Jan 2025 9:22am
abyss
Australia
Re: Update on part numbers.
thepetrolhead wrote:
I have been told these are the same
Part Number as L494 Range Rover Sport.
Please check before ordering.
When I do mine, I'll update the post.
Mine is exactly like this. 365mm disc.
Post #1056279 4th Jan 2025 9:26am
mmbanf
Italy
Hi Steve, sorry for the delay in replying, I hadn't seen the message, on the 20" rim you can install the 6-piston Brembo calipers and 380 discs, as you can see from the back of a complicated job.
Marco
Post #1056280 4th Jan 2025 9:54am
mmbanf
Italy
Hi, even for systems with 365 brake discs it is necessary to replace the wheel hubs, alternatively use caliper spacers of about 5 mm, a job that I personally do not recommend, given the workload on the brake caliper.
Marco
Post #1056281 4th Jan 2025 9:57am
Page 4 of 5 <12345>
