![]() | Home > Technical > Method to clean injectors (approved by LR) SSM40324 |
| Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2114
Models
LD - Defender LJ - Discovery Series I LP - Range Rover LM - New Range Rover LN - Freelander LT - Discovery Series II LA - Discovery 3 LS - Range Rover Sport LF - Freelander 2 Title Petrol fuel injector cleaning equipment Last Modified 30-JAN-2009 12:41 Category Engine Symptom 404000 Fuel System Concerns Content Issue: Fuel injectors clogged leading to potential problems such as poor running, poor fuel economy, excessive exhaust emissions, hard starting, rough idle, misfires and engine detonation. Cause: Poor fuel quality or fuel contaminants restricting the fuel injector flow rate. Action: Land Rover engineering now approve the use of the ASNU ultrasonic fuel injector cleaning system on Land Rover fuel injected petrol engines. If the equipment is purchased, training and operating instructions for using the system will be supplied by the ASNU representative. For fuel injector remove and refit procedure refer to Global Technical Reference (GTR) section 303-04. Contact details for ASNU and descriptions of the ultrasonic cleaning systems available can be found on the ASNU website (www.asnu.com) Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6728
This is only for EFi petrol engined Defenders - so the 50th Anniversary V8
You are right Eduardo
| Bullet Member Since: 21 Apr 2009 Location: Benoni Posts: 7
What about the diesel models?
| All times are GMT |
