![]() | Home > In Car Electronics > USB Charger for a Puma - recommendations please |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2377 ![]() ![]() ![]() |
A blue sea double usb from mud uk.
Shafski Member Since: 19 Jun 2023 Location: Chilterns Posts: 123 ![]() ![]() ![]() |
Hi.
Why would you want to lose the cigarette lighter and restrict future options, who knows when you may need that compressor/whatever? And with no easy way to the battery…? I added a MUD usb into a spare placement in the main dash, plus 2 more.. subtle ones. One into the MUD glove box, and a further one on the left of the dash on the shelf for passengers to use.. So you really want all those wires hanging around also when driving? Food for thought.. Ali express also.. cheap as chips for the side 2… Good luck https://www.defender2.net/gallery/albums/u..._1635.jpeg Shafski _________________________________________ 2015 110 Montalcino Red Utility "Harriet" along with Puma on I.C.E |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3596 ![]() ![]() ![]() |
I recently got one of these:
https://www.aliexpress.com/item/1005003406...0PAO82JRZC Quite happy with it and can keep the original radio. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 306 ![]() ![]() ![]() |
Just fitted the below to my Puma, looks factory.
https://www.mobilecentre.co.uk/defender-dual-usb-a-c-socket |
I have to admit.. that does look super neat
![]() _________________________________________ 2015 110 Montalcino Red Utility "Harriet" along with Puma on I.C.E |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 677 ![]() ![]() ![]() |
I have fitted numerous Blue Sea USB sockets to all the Pumas I’ve had, however they don’t fit properly and always need approx 1mm turned off the outer diameter on a lathe to achieve the perfect factory fit in the Puma dash cutout. I can do this for you if you like, it only takes a minute or so on my Myford.
The Mobile Centre one does actually look pretty good, but I’ve had that many Blue sea ones fitted to all the vehicles and also boats I’ve owned in the past ten years I think I’ll stick to them! |
Paddington Member Since: 15 May 2020 Location: Oxford Posts: 43 ![]() ![]() |
Dear all,
Thank you for taking the time to reply to my post. It is much appreciated. Whilst I have undertaken a number of modifications in the past on series vehicles and various Defenders, I am finding the Puma is a slightly different beast and i am keen to learn from the experience of others (as always). I'll have a ponder on what to do next. Thanks again. Kind Regards Neil |
andy2111 Member Since: 17 Oct 2021 Location: Kent Posts: 369 ![]() ![]() ![]() |
If you want to charge a newish smartphone then you will want a fast charging usb adapter so check the specifications before you buy.
I fitted one of these to my truck a couple of weeks ago. It supports both of the latest fast charge standards, is also compatible with older usb standards, and with the plastic cap on it blends into the background so doesn't look out of place. https://www.amazon.co.uk/your-orders/pop?r...B0BHN4HF62 TD5 hardtop to Puma inspired Poptop - my build thread 2002 110 TD5 Hardtop ¦ Full Puma interior ¦ Carpathian grey / Santorini black ¦ X-Vision-X poptop |
It’s a bit of a pig to remove the old cigar lighter. Mine really didn’t want to move so things got a little gash…
glpinxit Member Since: 31 Jul 2010 Location: rural Somerset Posts: 159 ![]() ![]() |
For the last 2 years I've had one of these via ebay "Baseus 65W Car Charger USB Type-C QC 4.0 Fast Charging Cigaretter Adapter Kit" (item number eBay Item No. 392824357824). Two types uf USB catered for and tells you the battery voltage too. I need to buy another fur the wife's car. It works well. Cheers, Guy.
