Home > Technical > Whining Noise! |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4507 |
Would'nt be something as simple the propshaft being fitted incorrectly i.e not lining up with the aligning marks?
Suppose you checked the coupling for adequate grease. Knowing you I feel sure you have eliminated both these causes. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
16th Nov 2011 7:34pm |
have a good look underneath in the light, I found a few stray items on mine, simply clipped into place.
also check around the brake discs and abs cables. did you lift the suspension ? If so, probably propshaft related, check you nipples too keep us informed |
16th Nov 2011 8:53pm |
Are you sure it wasn't Amy? My daughter is still off we bought a Defender "instead" of using the money to put down a deposit on a flat for her Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
16th Nov 2011 9:14pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
rear diff i expect
16th Nov 2011 11:02pm |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2007 |
Must be the wife
16th Nov 2011 11:04pm |
TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045 |
You can live in a defender, you can't drive a house |
16th Nov 2011 11:42pm |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 4990 |
Agreed, will do searches on rear diffs It's booked in for the 28th! Does anyone else have a noise once it's warmed up after a few miles at speed? and I couldn't think of a better way of spending your daughters inheritance ZeDefender |
17th Nov 2011 8:21am |
17th Nov 2011 8:46am |
party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311 |
That will be me tomorrow if you ask too many difficult questions..... Jon - 110 td5 [sold]. Currently Defenderless. |
17th Nov 2011 9:05am |
OK Jon, heres the plan, you ask the heavy questions and whilst they are distracted I'll whack in a few diffs and gearboxes into Johns sankey Have you got the hidden camera sorted for the factory tour yet
17th Nov 2011 2:10pm |
Vehicle seems very young to be giving diff. worries. 1982 88" 2.25 diesel
17th Nov 2011 8:06pm |
Yes 3300 miles now Spud, never towed anything significant in weight, never offroaded etc. The more I hear the noise the more I think it is the gearbox! I can get it to make the noise at 2000RPM at about 40 - 50 mph and can get it to be quite loud which is almost a relief so it can be identified easily hopefully sorted properly.
I will be towing 2 tonnes 200 miles the day before it goes in so that might help it up a bit more It sounds like a 1960's car gearbox whine, only when under load! |
20th Nov 2011 9:17am |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 |
Dont you all know?
"....They all do that, Sir." Good luck tracing this one. |
20th Nov 2011 10:07am |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 |
Even ice-creamers make noise? Input shaft bearings sometimes need re torquing? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
20th Nov 2011 11:31am |
