Home > In Car Electronics > Wiring harness for Alpine ilx705 problem
bluedefender2015
Hi
I am in the process of installing the Alpine ILX705 double din stereo, new fascia etc. I have purchased the Connects2 wiring harness to suit according to model etc. I have removed the old harness which uncoupled easily but as soon as I try to insert the new harness it doesn't want to know. I have compared new to old and all the blades are in the correct locations and the shape of the connectors is correct.
I wondered if anyone else had struggled with this part of the install and whether you used the Connects 2 harness also (CT20LR06).
Any help appreciated
Photo of original (left) and new plug (right) attached
Post #1005119 22nd Aug 2023 12:50pm
Shafski
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
Hi
I fitted the ILX-705 recently. I just used the harness that was behind my original single Din pioneer. No problems at all.
Problems lie trying to get the Censored into the dash with the miles of cabling.
Patience and calmness required..
Try try and try again.. and she will eventually go.. eventually Rolling with laughter
https://www.defender2.net/gallery/albums/u..._1638.jpeg Shafski
_________________________________________
2015 110 Montalcino Red Utility "Harriet" along with Puma on I.C.E
Post #1005191 23rd Aug 2023 11:38am
bluedefender2015
Thanks for that, I managed to get the Connects harness to engage with the original socket in the end, a bit of fiddling with the blades sorted that.
You are right about getting the fascia back on. Just spent an hour fiddling with it and no joy so far. I'll try again another time!!
Did you take the metal bracket out before you did yours?
Thanks
Post #1005944 30th Aug 2023 6:48pm
Shafski
Hi !
Sorry for the late reply.. time runs away..
Yep.. that metal bracket came out.. and then it was still a challenge..
Thumbs Up Shafski
Post #1008128 19th Sep 2023 9:18am
