Home > General & Technical (L663) > Advice sought on roof bars loading
Ritson
France
Hi All,
I’m looking for some advice regarding the LR roof cross bars (not roof rack).
I need to transport a 5m long Thule sun canopy which weighs 52kg. I’m wondering if the LR roof crossbars are up to the task, especially as it would result in a 2.1m overhang front and rear as the bars are only 80cm apart.
Has anyone any experience of transporting anything similar on their bars?
Cheers Current: MY22 P400e SE
Prior: Discovery Sport HSE, Jaguar F-Type S, Discovery 3, RR Vogue
Post #1004637 18th Aug 2023 5:38pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
According to Land Rover the maximum load that can be placed on the cross bars is 94 kg so you should be ok weight wise but I haven't tried it as I have the roof rack Confused
Edited to add all the warnings from Land Rover
The load must be evenly distributed over the area of the cross bars as illustrated. The centre of gravity of the load must be kept as low as possible as illustrated.
Do not overload the cross bars. Maximum load that can be placed on the cross bars is 94 kg or 207 lbs.
Do not exceed the recommended gross vehicle weight (GVW).
Do not load cargo, or accessories, outside of the width of the cross bars.
Always secure long loads, those significantly exceeding the length of the roof, at the ends of the vehicle.
Always spread the load as evenly as possible, on the cross bars, with the lowest possible centre of gravity. Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1004658 18th Aug 2023 7:43pm
Ritson
France
Thanks Hairy Dan,
Yep, its the issue of the length past both ends of the bars that concerns me. I knew that the weight of the canopy is well below the rated weight of the crossbars but its the fact that most of that weight is going to be overhanging the bars that is the potential problem. I was hoping somebody who may have used them to transport a windsurfer sail or similar might have be able to clue me in
Post #1004664 18th Aug 2023 8:07pm
Defendit..
Netherlands
If you got the genuine LR part (VPLER0178), it is pretty limiting: The bars are fixed length (a shorter one and a longer one) which fit at the notches in the roof rails, but don't really fit anywhere else (as the roof rails are not parallel).
This means you cannot space them really far apart if you need to.
The Thule option allows the bars to be placed anywhere, as their length is adjustable. No Mud flaps for my 90.!
P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #1005171 23rd Aug 2023 7:48am
Ritson
France
Yep, I have the original LR part, nd as you say its pretty limiting! Never mind, I'll find a way Confused Current: MY22 P400e SE
Post #1005187 23rd Aug 2023 10:43am
markb110
Don't forget that they also state a maximum speed limited in the installation instructions. Normally 80mph if my memory is correct.
Post #1005188 23rd Aug 2023 10:46am
XplusYplusZ
It sounds like the weight is fine, but the question is more about the intrinsic strength/integrity of the awning itself. I guess it depends on the strength of the aluminium casing.
Which Thule awning is it?
It looks like all the guidance is to have the fixing plates right at the ends of the awning
Given the amount of extra weight the bars can take, could you potentially add a long 3-4m, strong (steel) reinforcement plate which fixes onto the bars to add a bit more rigidity further out from the crossbars themselves?
Are you just transporting it, or are you planning to use it on the Defender?
Post #1005203 23rd Aug 2023 2:31pm
Ritson
France
its a Thule Omnistor and I'm just transporting it the once so don't want to go any great lengths/costs to do so. Think I've found somebody with a van I can borrow so that'll be much easier!!! Current: MY22 P400e SE
Post #1005204 23rd Aug 2023 2:35pm
