Home > V8 > Won't start.....
Ranger 6
United Kingdom 1988 Defender 90 V8 Petrol CSW Rimini Red
Won't start.....
Scenario:
Drove the car in and stopped - switched off and walked away - it was running completely normally
Came back to the car a few days later - won't start - turns over freely
The car is a factory built one - not a conversion, and all parts are standard
Symptoms:
There is only one spark (tested with a plug) at the start of turning the key and another spark when turning the key off
Otherwise the engine will not run
Tested/changed:
New Ignition module (tested and changed) - it's a two pin module fixed to the side of the distributor
Distributor - std fit electronic ignition - hall effect sensor checked
HT leads - resistance check
Ignition switch bypassed to coil
New coil
Earth checked (bypassed with HT lead)
Stumped a couple of experienced mechanics who have had a look
Next thing to change is the HT leads and try that - we have swapped them to see if the king lead has died, but no difference
So, what could be the 'fix' here? 90 V8 CSW - 1988
Post #1004353 16th Aug 2023 3:14pm
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
Is there definitely fuel delivery? Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #1004381 16th Aug 2023 5:57pm
Ranger 6
yes - it's a spark issue not a fuel one 90 V8 CSW - 1988
Post #1004400 16th Aug 2023 7:59pm
BaronDefenders
Tried a new rotor arm? Charlie
2002 Td5 90 (SOLD)
Post #1004401 16th Aug 2023 8:03pm
DonH2000
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
Wondering if your car is old enough to have an Alarm Spider in the dash board.
I had a Discovery 1 V8 1996 and they had known issues with it. It immobilizes the engine but it will still turn over.
There is available on a ebay as bypass wiring fix which is plug and play.
Good luck
Don Cheers Don.
Post #1004482 17th Aug 2023 12:31pm
Ranger 6
Thanks all
Charlie - Yes
Don - no, it's too old to have anything like that
I'm purchasing a new Hall effect sensor for the dizzy and a new king lead - it's had an ignition amp and coil so far (as well as some wiring and checks with spare parts) 90 V8 CSW - 1988
Post #1004999 21st Aug 2023 4:07pm
DonH2000
Good luck,
Don Cheers Don.
Post #1005013 21st Aug 2023 6:05pm
Nuclear Nick
Just curious to hear if you got this fixed and what the problem was?
Post #1007689 15th Sep 2023 9:20am
Ranger 6
Sorry - no, still not running
Made the decision to find someone to do much more to it. I have another engine to go in and need some bulkhead work done at the same time.
I'd like somewhere local to me that can take it, fix it and bring it back in a better state.
Suggestions have been Safari Engineering in Eversley as the local places have either closed or don't do welding. 90 V8 CSW - 1988
Post #1008070 18th Sep 2023 5:19pm
Nuclear Nick
Thanks for coming back - I hope whatever is done sorts out the issue for you.
Post #1008074 18th Sep 2023 5:45pm
Ranger 6
Cheers - in the middle of rally season at the moment so the 90 is on the back burner
3 Shires and Rally Yorkshire over previous weeks and the Mull Rally next week followed by Bovington Very Happy 90 V8 CSW - 1988
Post #1009903 3rd Oct 2023 1:05pm
Ranger 6
Final update on this one.
It's being collected next week and I don't expect it back for a while. The bulkhead is going to be done as well as the engine build and a whole host of new bits to make it all work.
Oh my aching wallet!! Laughing 90 V8 CSW - 1988
Post #1014563 9th Nov 2023 6:24pm
L110CDL
Laughing
It will be well worth it when you get it back again Thumbs Up Clayton.
Keeper.
Post #1014595 9th Nov 2023 9:30pm
