Home > Puma (Tdci) > Puma mileage, how long will the engine last?
Page 1 of 4 1234>
lightning
l've been looking at 2012-2016 Defender 110's and there's a large difference in price between high and low mileage.
Ignoring the silly priced ones, l've seen a 15,000 mile XS 110 SW at £38,000
A 34,000 mile same model for £35,000
And a nice 2012 again 110XS SW with 125,000 miles at £21,000
All three vehicles look to be in good condition with signs they've been loved (no rusty bolts, interior has no rusty metal parts, extra soundproofing, good crossmembers etc)
So, if l buy the 34,000 mile one and keep it a few years at 12,000 miles
per year l am going to reduce its value to £20,000.
Which makes me think, how about the 125,000 mile one. And here's my question. Will a TDCi go to 250,000 without the engine calling time?
l've seen TD5's at that mileage still fine but l don't want another TD5.
How does the TDCi compare when you get to 200,000?
Post #1004149 14th Aug 2023 10:57pm
MK
some users here have 2.4 tdci´s with 300-400 kkm on the clock. I guess most of these engines will pass the 250 kkm. I am sure some have blown their engines much sooner than that. Puma 110" SW
Post #1004151 14th Aug 2023 11:07pm
LR90XS2011
there is a high mileage thread on here somewhere DEFENDER 90 TDCI XS,
Post #1004162 15th Aug 2023 5:14am
Dinnu
Irrespective of engine life and durability, getting the £21,000 will leave you with at least £14,000 in your pocket which is more than enough to replace the engine and buy some proper diffs.
I see that with engines, from any manufacturer, there had been constant improvement up to late 90s, early 2000s, after which reliability started to drop off again. Maybe caused by the drive to make them more economical, lighter and cheaper, or perhaps the added emissions control.
Keep also in mind... that most would post about issues on their engines / Defender. Very rarely people post on how reliable it has been.
When I bought my last Defender, a 2.2, it was already over 100k, and the engine/mechanicals where at the bottom of my check list. I give more priority to the condition of the body/chassis particularly regarding corrosion. However mine does not need to work for living! 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1004164 15th Aug 2023 5:36am
BrickBox
Personally, I’d go for the 2.4. I’m biased of course.
Lacks the DPF and oil dilution issues. That’s a big factor in engine failure is diluted oil. 2017 5.0 V8 Supercharged RRS SVR
2008 2.4 110 Utility Station Wagon XS.
Post #1004168 15th Aug 2023 7:15am
hank
What you have to remember is that these engines are also found in Transit vans which often get abused with little to no maintenance... But go on and on and on. As well as black cabs which use them because of their proven reliability and longevity
They are reliable units, particularly when treated well. Yes there are low mile horror stories out there but these are anomalous and the same applies with anything mechanical - there will always be unexplained premature failures. > 110 XS Double Cab
Post #1004172 15th Aug 2023 7:26am
Grenadier
Or get the 2.4, and use the £14k difference to put in a M57 with autobox. Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #1004178 15th Aug 2023 8:21am
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
Next Meridian https://nextmeridianexpedition.live are driving their 2.2 Puma around the world and it started the trip with 100kms on the clock. So far so good, nothing major to fix. That should give you some confidence.
Post #1004180 15th Aug 2023 8:24am
NoLimits
United Kingdom 2013 Defender 110 Puma 2.2 USW Havana
This, definitely do this Very Happy
Edited to say...
I bought my 2014 2.2 110 with 120k on the clock, I have done nothing to the engine apart from upping the performance with a BAS 170 ecu and intercooler upgrade.
The drive shafts, half shafts and transfer box shaft on the other hand, have all had to be replaced as there was a lot of play in them, but the engine has been fine.
Post #1004197 15th Aug 2023 10:07am
swt
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
My 2.4 has 120k miles on the clock and the only things that have failed near the engine or its ancillaries have been the VCV (obvs!) and a stretch bolt holding an injector clamp. The mechanic I used when we lived in Hertfordshire worked on Defenders, Transits and taxis a lot, and so saw a lot of this engine. He reckoned it was about as reliable as any, and was good for a few hundred thousand. It would certainly be low down on my list of concerns buying a vehicle.
Post #1004200 15th Aug 2023 10:26am
266k miles on my 2.4 now, it's had a new water pump, new aux belt pulley bearings, several VCVs, exhaust manifold gasket, and one new aux belt, but I don't remember any other engine parts. Timing gear, injectors, etc, are all original at present, injectors have never been out. It has a Provent fitted which I think helps assure longevity of engine life.
The driveline is a different story, LT230, propshafts, diffs, halfshafts CVs have all been replaced and upgraded, it's on its fifth (I think) clutch although the most recent has now done 120k miles.
Post #1004203 15th Aug 2023 10:34am
lightning
Yes there's the 2.4 option as well.
l use the vehicle for my business and do a lot of short journeys every day, so would that be a problem with a 2.2?
Post #1004217 15th Aug 2023 11:15am
Grenadier
What's a Provent BW? Monsieur Le Grenadier
Post #1004220 15th Aug 2023 11:20am
swt
The 2.2 has a diesel particulate filter for emissions purposes, which the 2.4 did not. The DPF needs to regenerate at higher temperature from time to time, which is less easily achieved on short journeys. There have been a number of discussions about this: an occasional longer run at speed keeps things running.
Personally, I am glad of my 2.4, there being less to go wrong, one less warning light to be troubled by etc. Its my daily drive and does high miles in short bursts on slow rural roads. Horses for courses, but I'm sure a 2.2 would be just as good.
Post #1004231 15th Aug 2023 12:33pm
It's a catch can fitted in the engine breather system to separate the gunky stuff from the gas. There are many threads on here about them.
Anything that can be done to prevent the engine reingesting its own waste is good for engine life, disabling the EGR especially so, but sadly that would be illegal so of course we wouldn't do it.
Provent pictures can be seen at the randomly-selected link below.
https://www.darksidedevelopments.co.uk/pro...ystem.html
Post #1004237 15th Aug 2023 12:50pm
Page 1 of 4 1234>
