Home > Td5 > 2002 TD5 - Hightlight issues with both old and new LEDs
docperio44
Canada 2002 Defender 110 Td5 CSW Stornoway Grey
Hi All,
I recently got a 2002 TD5, I did not notice but the headlights were always on when the car was started and ignition was on. I recently changed the lights to LED with a halo DRL and still have the problem. Here are the facts:
On the ignition, after the first click (short turn), I can put the light switch in position 2 and the parking lights work and the halo. In position 3, it is the same, the headlights don't come on - parking lights and DRLs are on.
When the second click and full ignition - when all the instruments come on, the headlights come on full blast in position 1,2, or 3. There is no diming between 1,2, or 3. There is not shutting off the lights.
I replaced the switch and I still have the same problem.
This doesn't sound like the dim dip issue? Any ideas?
Thanks!
Post #1003380 8th Aug 2023 3:55pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
If I was you I'd be checking the full run of the headlamp wiring from the switch forwards. It sounds like someone has modified the lighting circuit so the headlights run full time.
Look for a floating relay somewhere behind the instrument binnacle or in the engine bay.
Post #1004054 14th Aug 2023 9:58am
docperio44
Thanks, yes that's exactly what it was. All set!
Post #1004057 14th Aug 2023 10:03am
Penfold_6290
Was it carnage back there or was it easy to put right?
Post #1004063 14th Aug 2023 10:45am
docperio44
Some carnage -- tapped all the wires into the light switch then down into a mod within the fuse panel. a challenge but not horrible
Post #1004064 14th Aug 2023 10:50am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
If you have not already done so, you should install a headlight wiring loom to take the load off the switch. Glad you got your issue sorted. Thumbs Up
https://www.ebay.ca/itm/363852631160?fits=...BMqt_pnb9i 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1004257 15th Aug 2023 3:45pm
