Home > In Car Electronics (L663) > Editing Favourites in Pivi Pro
martinf
In the last few weeks I have wanted to use destinations I have been given in What 3 Words. These are usually for locations relating to such things as dog training where it maybe a gateway to a field. If I put the 3 words in the search box of the satnav it finds the location and will navigate to it. So far so good.
However, if I save it as a Favourite it does so with the 3 words as its name. Not much use if several such favourites are saved so I want to edit the name of the Favourite but can't find a way to do so. In my L405 this was easy.
Any ideas how to do it in Pivi Pro?
Post #1003841 12th Aug 2023 7:47am
DaveCNB
United States
Editing a favorite in the Privi GPS
So after you save a destination to your Favorites,
Go into your list of Favorites (yellow star in a circle icon) in the Privi Nav search screen
Press the Pencil icon at top left (circled in red):
Select the saved Favorite that you want to edit.
To edit the name, again press on the pencil icon (circled in red):
That will bring up a full screen keyboard so you can change the name. Click the blue OK button bottom right when you're done, make sure to select the Check/OK icon at the top right to save your changes:
That should do it.
Cheers,
Dave --------------------------------
"Chonky" 2024 Defender 110 X-Dynamic SE P400, Pangea Green, Air Suspension, Off Road Pack, Urban Pack (exposed recovery points), Factory Side Steps
Post #1003911 13th Aug 2023 12:06am
martinf
Many thanks. Problem solved.
Post #1003926 13th Aug 2023 8:21am
