Home > Puma (Tdci) > Not starting and not locking.
Crofter
United Kingdom 2009 Defender 110 Puma 2.4 USW Baltic Blue
I cannot lock my 2009 Defender the door locks close then open, or that is how it sounds.
Also the defender will not start.
The engine turns over quickly but does not start.
What should I be looking at.
Or what can I try.
Thanks
Post #1003783 11th Aug 2023 4:45pm
MK
I am not sure but all suggests it is related to the immobilizer. Puma 110" SW
Post #1003791 11th Aug 2023 6:29pm
Crofter
Looks like I may have a us drivers door switch, could that be part of the problem?
Post #1003795 11th Aug 2023 7:16pm
spudfan
Ireland
I would change the immobiliser battery. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #1003806 11th Aug 2023 8:41pm
Crofter
Is that the battery in the fob?
Post #1003807 11th Aug 2023 8:49pm
spudfan
Ireland
Yes. It can cause all type of problems if low. Do the procedure in the hand book. If it works it will be a cheap fix. If not...more head scratching! 1982 88" 2.25 diesel
Post #1003808 11th Aug 2023 8:55pm
Crofter
Ok thanks I will try and get one tomorrow
Post #1003811 11th Aug 2023 9:13pm
spudfan
Ireland
One thing you could do is to lock each door individually from the inside with the door lock button. If they lock your locking mechanism is O.K. Another problem that can prevent locking is the actuator on each door's locking system. But it is strange for them all to go at once. A sympton is the latch trying to go down but won't. That means the actuator on that door needs changed. One door not locking could be, and usually is caused by a broken wire in the wiring at the door. As yours lock and unlock means non of these apply to you. Hopefully the new battery will sort it, but like I said earlier go through the correct procedure out lined in the handbook. Good luck. 1982 88" 2.25 diesel
Post #1003815 11th Aug 2023 9:23pm
Crofter
I will give that a try just now.
Post #1003816 11th Aug 2023 9:27pm
Crofter
Looks like a solenoid fault on the drivers door.
Pressed it down then pressed lock on fob. So it is secure tonight.
Still would not start but I can look at that tomorrow.
I have the front wheels up on ramps just now, started earlier and drove onto the ramps around lunch time.
Thanks
Post #1003817 11th Aug 2023 9:38pm
Crofter
Would not start first thing this morning I though it would be cooler.
Got a hand to push it off the ramps and it started first time.
Is that air in the fuel line?
Post #1003847 12th Aug 2023 10:07am
MK
Did you just change the fuel filter? and
So, does it start ok now? Puma 110" SW
Post #1003871 12th Aug 2023 3:17pm
Dinnu
There could be an leak in the fuel system. The 2.4 needs to suck the fuel from the tank, and if parked with front wheels on a ramp, a small leak will draw air into the system, rather than leak fuel out, making it difficult to start. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1003873 12th Aug 2023 3:34pm
Crofter
I did have it serviced last month.
Also an air leak would sound possible.
Post #1003875 12th Aug 2023 3:59pm
