Home > Puma (Tdci) > MT82 gearbox / clutch change African style.
Timcat
United Kingdom 2012 Defender 110 Puma 2.2 SW Indus Silver
Henry the 110 has thrown another spanner in the works ( a week after rebuilding the rear LSD!)
The gearbox is rattling like a skeleton breakdancing in a biscuit tin! Sixth gear is un-useable & we have ordered a re-con box from SA & a complete clutch kit & master from LOF ( thanks to Luke at LOF)
Question is is there any shortcuts ( easier way) of changing it out? Will be done on the floor, it’s going to be a pain as the diesel heater under the cubby will have to come out as well.
Been reading my trusty Haynes manual & seems quite straight forward.
Post #1003571 10th Aug 2023 9:05am
MK
Don't forget to check the gearbox output shaft assembly Puma 110" SW
Post #1003609 10th Aug 2023 1:43pm
Timcat
Running an Ashcroft output shaft that will be swapped over👍
Post #1003613 10th Aug 2023 2:08pm
NickMc
Think they’re actually easier to do on a Tdci than a Tdi or td5 in my opinion.
Post #1003693 10th Aug 2023 10:31pm
