![]() | Home > Tdi > 200tdi power loss - running out of ideas |
Mean Green Member Since: 15 Sep 2011 Location: South Ayrshire Posts: 280 ![]() ![]() |
So just as an update - I changed the lift pump to a Delphi one. As soon as the old one came off and was beside the Delphi there was a noticeable difference in the pumps. The new Delphi was generally bigger, the bowl on the top was a little deeper and wider, the pump arm seemed to measure about 2mm longer. I do remember changing the lift pump, but that was a good few years ago (although it has been off the road for about 6 years) - i seem to remember it came in a blue box!!!
As a result the 90 is now much more responsive and was happy sitting at 65 rather than struggling at 55 (I think it would have gone a little more, but there is a bit of play somewhere in the steering which is more pronounced at speed, so didn't want to push it too much). |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11083 ![]() ![]() |
Good result you finding the problem
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 600 ![]() ![]() ![]() |
I was going to suggest the lift pump. Although I didn't notice any power difference, it was pretty flat before the cheap lift pump broke. As you did I fitted a Delphi one after. Glad it's fixed.
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 881 ![]() ![]() ![]() |
@Mean Green, Might be worth you reading this.....
https://www.defender2.net/forum/topic85417-15.html Changing the lift pump may have been the fix, but possibly not for the reason you think. |
Cheers I-L-O-S
I had already seen that post. I had the 90 out yesterday for the 1st real run since the rebuild - 90 miles to DefenderJam and back. It is now happy to sit at 65ish - not pushed it much more that that at the moment as there is a bit of vibration/play/vagueness in the steering - I think the tracking might be a little out, and the wheels need balanced. Once I get it handling better, I do think there is a bit more power that can be teased out of it - even before any modifications. |
My old 200tdi 90 was stock standard, but well maintained and would regularly do 75-80mph on the flat and more down hill (Have seen 90+ on the speedo but not vouching for the accuracy....).
You definitely need to have the suspension/steering in A1 condition and dialled in correctly. I could drive mine down the 3rd lane at 80+ with just a couple of fingers on the steering and it would track straight at speed and under breaking, even on mud terrain tyres. Whenever other people from the 4x4 car club passengered with me they were always amazed at how calm and controlled it was as they always said they felt like their landrovers were trying to throw them off the road and kill them once they got above 65-70mph ![]() And I set my own tracking with an extendible pole. |
