![]() | Home > In Car Electronics > Key fob battery replacement |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1274 ![]() ![]() |
You need to PM ..... RRUK ..... he does the refurb of key fobs
https://www.defender2.net/forum/topic78289.html?highlight=key |
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 782 ![]() |
What age Defender and what style of fob.
I’ve just done my 2009 two button fob, just take it off the ring and prise the two parts apart. 3v battery will have a battery number on it, can’t remember what mine was. Swap battery, snap it back together and off you go. |
swt Member Since: 24 Aug 2018 Location: Cumbria Posts: 167 ![]() ![]() ![]() |
If you have a two-button 'Lucas' style fob, part no. YWX101200 (2007-?2014) it's a CR2032 (3 volt). You open the fob by prising apart at the end where the key ring attaches. There is supposedly a procedure, set out in a post somewhere on here, but mine (2008) has never cared if I change the battery far from the vehicle without telling the alarm ECU what I am about to do... occasionally I have to realign fob and vehicle by pressing the button multiple times after the change.
steveww Member Since: 05 Jan 2022 Location: Malton Posts: 607 ![]() ![]() ![]() |
Thanks for the help. I figured it out and swapped in a new battery, I can now zap with confidence.
