![]() | Home > Puma (Tdci) > harder steering after impact |
| Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3649
You say that the drop arm was bent?
Then most likely the sector shaft inside the steering box is bent too. If so, the only remedy is a replacement steering box or a new sector shaft, but probably the former option is better and possibly cheaper. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
| nicolas0505 Member Since: 23 Dec 2020 Location: briançon Posts: 80
I said the shield came in contact with the pitman arm. the vehicle still drives the same. Is it normal that I have no play in the steering wheel when the wheels are straight, the wheels turn directly, shouldn't the steering box be adjusted? I only have stubborn game
There should be minimal to no play in the steering gears when steering is dead straight, but will have play when getting closer to full lock (either way).
Best way to check for play is from the drop arm itself, not the steering wheel. But to do so, you would need to disconnect the drag link. Could someone have over adjusted the steering box? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
