Home > Puma (Tdci) > Puma dash connector help Down Under!
Defabeng
Australia
Edit... Thanks, I have managed to find one in a wreck down here.. Thanks
Hey Guys, I run a small defender workshop here in australia. Got a Problem with a customers 2.4 puma. The electrical connector that plugs into the rear of the dash has a broken camlock and its causing big issues with not running. Does anyone know where I could get a new connector in the UK? I have found a part number but it only supplies the black pin block inside the grey plug.. I really only nee the little black camlock but will buy a complete connector if only I could find one. Contacting uk parts shops has proved un fruitful so far... maybe even one from a breaker? Getting pretty desperate and the next step is an entire new loom which is pretty rediculous. m Please help my fellow defender nuts from the motherland.
Post #1002336 31st Jul 2023 3:28am
PaulMc
I can supply just the connector cover with camlock - but, postage to Australia will be several times the cost of the part.
I'll see if I can find somewhere nearer to you that can supply. Paul.
Post #1002355 31st Jul 2023 8:30am
Martin
Site Admin
Available on the site shop:
https://defender2.net/shop/defender-puma-t...0-p86.html  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1002358 31st Jul 2023 9:17am
