Home > In Car Electronics > Can anyone identify this purple connector please.
icarus001
I had to take the dash off my 2013 2.2 Puma to get to the windscreen wiper mechanism and I can see this purple connector but I cannot figure out where it goes?
Also the white wire with black wrap on it, that runs from the alarm/immobiliser and is hanging over the metal strut, it's broken - I don't know where it came from either but I think it's the door sensor which is from what I can see is a normally open switch anyway so won't affect anything?
Thanks.
Post #1001601 24th Jul 2023 9:18pm
rustandoil
I think the "broken" wire from the alarm module will be the antenna.... I have no idea about the purple connector ☺️
Post #1001610 24th Jul 2023 9:43pm
NickMc
Yeah the one extra loose with the black stuff is for the alarm antenna and has been lengthened to probably tuck in behind the screen pillar trim.
Looks like the other wiring is an add on, aftermarket alarm/locking or windows?
I would address the leak you have either at the screen or screen bracket as it’ll wreck your alarm box eventually while you have it off Thumbs Up the water staining has begun.
Post #1001614 24th Jul 2023 10:05pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
If those wires with that extra fuse are green-white and green-red they are the outputs to the hazards/indicators. So, yes, probably an aftermarket alarm connection.
Post #1001763 25th Jul 2023 6:34pm
