![]() | Home > In Car Electronics > Wiring for dummy’s |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6696 ![]() ![]() ![]() |
The original heater blower/fan wiring looks like this.
![]() Click image to enlarge There's a three-position switch (off, slow, fast [less slow!]). This works by switching a path to ground on either the green/yellow (slow - goes via the resistor in the fan assembly) or green/grey (fast) wires. Are you missing the original left hand side sliding fan switch on the instrument binnacle? Assuming you are to continue with the aftermarket switch and the original green/yellow and green/grey wires are still in place, you want to connect + [input] to whichever of those wires you want to use (slow or fast). Connect A [output] to the black wire which should be the same size (cross section/diameter) as the green/yellow and green/grey. ![]() ![]() |
Dick Member Since: 06 Jul 2023 Location: London / Devon Posts: 81 ![]() ![]() ![]() |
It looks like the green wired connecting the heater are still in place.
I think the white wires / switch are a replacement for the sliding 2 speed dash switch replacing with just on or off. Will trace those Green wires in the hope they’re still connected to soemthing to connect in to finish this circuit, although it looks like the toggle switch is already wired right in to the relay before the heater matrix: ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Green wires are all still in place.
Looks like a new motor on the bottom of the heater unit which has been wired straight to that switch on the dash. My guess is the old motor and speed selector has given up and rather than replace the whole blower unit a new blower fan was added. Still nonethewiser where the second white wire should be routing to - is it just a ground/earth? Looks like the new blower motor has power to it from red/black ![]() Click image to enlarge |
OK so it's not standard at the blower end!
Without seeing the wiring of the bottom of the relay (curious as to the 5 wires to a 4 pin relay..) but you won't damage anything by connecting your loose ring terminal incorrectly, it won't short out anything it just won't work. It is likely, as it's a ring terminal, that it's intended to go to a ground point behind the dash - but that is an educated guess not a guarantee. The wiring of the bottom of the relay will tell you if the white wires is intended to be switched to ground or 12V to trigger the relay. ![]() ![]() |
Yeah it looks annoyingly cowboy.
Another thing to add to the list- replace blower and switches 😂 Will try grounding it and see if it works as that seems the most likely explanation as to why I can’t find where it came from - was probably hooked through a bolt and came off as I was undoing one of the eleventy billion ![]() So will ACC go to ground or + in this case? Or just trial and error?! |
It won't matter which way round the + and A go, as you're not using the LED in the switch.
But it would be good practice to do + to the wire going off to the relay, and A to ground. ![]() ![]() |
Thank you good sir!
Will let you know how that goes! |
Earthed it and all good.
Revived the asthmatic wheeze back to its former glory! Thanks for your help Martin! |
