![]() | Home > General & Technical (L663) > Fitting rear speakers in a Commercial |
Paladino Member Since: 07 Dec 2022 Location: Serbia Posts: 30 ![]() |
I will try to fit the rear speakers in the next period. There is no wiring in the door, new wiring is needed. You will need it anyway if you want to activate rear windows.
The problem is that it looks like that there is no wiring from the headunit under the seat to the door connector, I will try to find the pinout and and add cables. What I don't know is if the rear channels are disabled and need coding. |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 457 ![]() ![]() |
Assuming you drive the 90 commercial.
You have to check if the speaker brackets are mounted behind the speaker grille. Cables to the amplifier in the rear can be easy made. See my thread: https://www.defender2.net/forum/topic83928.html No Mud flaps for my 90.! ----------------------------------------- P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
It looks like the wires from the speakers go to the aam located in the rear of the vehicle. New pins from lr would be needed for making new cables. Currently we have only positive two negatives, can hi low and two small wires
![]() Click image to enlarge ![]() Click image to enlarge |
It looks like the two small wires are speaker wires. Green and yellow brown for the rear left door.
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3337 ![]() ![]() |
There's an opportunity for someone like Powerful U.K. to start producing a wiring harness and speaker mounting kit
Rear speakers make quite a difference even if they're not that good. lf the module is in the rear of the vehicle at least it won't be too difficult to route the wires if necessary. |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2702 ![]() ![]() |
I can't see anywhere for the speakers to be fitted in my commercial 110. The rear door cards are completely different to a station wagon. Would it need the CCF sorting to let the car know the speakers are there? So you could sort the balance of the speakers in the pivi system? 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
My 90 still has the speaker grilles in the rear. On the media screen the audio control still shows rear speakers and you can use the front/rear fader but of course it makes no difference to the sound.
I found out that there are no cables installed from the amplifier to the rear doors. There are only 4 wires going to the front two doors. I assume that there is a crossover somewhere between the door speaker and the tweeter.
