Home > Puma (Tdci) > Oil leak on the left
Minch90
hi Hive mind,
Daisy (09 2.4 63000mi) has a leak. Have cleaned the sump and bottom of engine with brake cleaner, looking underneath it comes from the left (looking at the engine) in the area shown in the pics, can’t see anything higher up but haven’t taken the fan cowl off yet to explore.
She does have a weeping gasket on the vacuum pump that is going to be replaced and I can trace that down separately; oh and the sump plug is a bit leaky too!
But any thoughts on this one please, she’s a daily driver so would rather be prepared and get all done at once with an oil change if I can.
 2.4TDCI 90 - everyday brilliance
S3 V8 Lightweight - in the garage being ignored #newchassistime
S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down
S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround
Post #1000939 20th Jul 2023 10:10am
MK
Front crankshaft seal? Puma 110" SW
Post #1000990 20th Jul 2023 3:04pm
Minch90
Thanka MK that makes sense, so replacement would be this… https://www.defender2.net/forum/topic24247.html 2.4TDCI 90 - everyday brilliance
Post #1000997 20th Jul 2023 3:40pm
MK
But before taking that way I would change the vacuum pump gasket and give another clean with brake cleaner or alike and a cloth. Then check it again. Puma 110" SW
Post #1000999 20th Jul 2023 3:49pm
Minch90
👍👍 2.4TDCI 90 - everyday brilliance
Post #1001010 20th Jul 2023 4:38pm
