![]() | Home > Td5 > wing wiring loom help |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18033 ![]() ![]() ![]() |
On a TD5 (which unlike the TDCi always had full wing harnesses) I'd expect there to be the headlamp adjuster connector unused on both sides and either the BBUS connector or the alarm sounder connector, whichever you don't have fitted, on the nearside.
olistr Member Since: 29 Dec 2022 Location: BW Posts: 69 ![]() ![]() |
hi
then it doesn't sum up. (oh didn't count the dbus, that one was clear for me, but the dbus is there on the left wing harness in addition to the not connected one. The head light adjuster/levelers were connected. |
Nearside may have a connector for a rear washer pump as well. I missed the levellers in your list, sorry. Both sides should have a horn.
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 537 ![]() ![]() |
Purple/black is usually horn trigger wire,black/green rear washer pump
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 511 ![]() ![]() ![]() |
Purple/Black and Black in a 2-way MQS connector, in each of the wing harnesses, is for the LH and RH horns.
Black/Light Green and Black in a 2-way Econoseal connector, is for the rear washer pump. Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Hi everyone,
thanks alot for the quick responses that seems about right, so I can install a second horn to scare ppl more ![]() Rear Washer pump is not available on the double cab. Lets see for what I'll misuse that one ![]() |
A more interesting question is why is one horn missing , it would have been built with two. On my DC the rear screen wash harness plus (upgraded) pump now runs the headlamp washers.
You had two horns??
like the devel
![]() I just realised there is another connector on the right wing loom that is unused too, it is a little closer to the blulkhead side wonder what that is. ![]() Click image to enlarge |
That looks like the (Econoseal) connector for the dim-dip resistor.
The wire colours will confirm. Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2243 ![]() ![]() ![]() |
Likewise, my boggo base-model 02' DCPU had only one factory fit horn.
Strangely mine did have the additional horn ('alarm sounder') fitted from factory despite the alarm not being enabled! 02' 110 TD5 Double Cab Rebuild Thread |
Could it be the EGR solenoid connector? |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
No itβs the dip dim resistor that attaches to the inner wing.
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 1000 ![]() ![]() ![]() |
2002 Defender wiring diagrams ππ»
https://drive.google.com/file/d/1Isfy6R3p7...tJ_h1/view 2020 range Rover Mk IV Autobiography PHEV 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
