Home > Maintenance & Modifications > Defender Rear Sliding Window Locks.
humby
United Kingdom 2015 Defender 110 Puma 2.2 SW Indus Silver
Hello! I had a quick search surprised i got no results. Or bad search string.
These window locks. Are there any recommended after market security improvement options?
Outside of going solid glass. Razz
Ill spend some time on google but be interested to know whats tested and proven. Thank you[/img]
Post #1000844 19th Jul 2023 5:05pm
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
Funnily enough - one of mine came off in my hand this week due to bi-metal corrosion from over 12 years by the sea side
I ordered on in from John Craddock and it was the same as the original one - took 10 mis to swap over and now toying with the idea of changing the other one later in the year ...
Never had a problem with these from a security point of view but have internal window grills fitted for the camper set up anyway ... so one of those ‘layers' to slow down possible issues
Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #1000855 19th Jul 2023 5:56pm
humby
To be honest i hadn't thought about security for those latches and i did recently change the exterior aluminium blocks as mine had weathered badly.
It was only today as i stopped to chat to a neighbour that has a load of defenders out front that mentioned those rear latch windows you can open a particular way that got me thinking about it.
Ill spend some time googling, i dont have any grills on my windows if i can avoid them too id like to be grill-less Very Happy
Post #1000873 19th Jul 2023 7:46pm
humby
So seems like the only product for the slide windows is guards. There is no aftermarket lock mechanism etc that can be installed to add a layer of security to the sliding windows.
Post #1001591 24th Jul 2023 8:18pm
excossack
Or a bit of wood between the lock and the other glass section of the window? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1001599 24th Jul 2023 9:14pm
humby
You gave me an idea! I am working on something.
Post #1001741 25th Jul 2023 5:31pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
I have blue box sliding rear side windows on my 110 CSW and they have a completely different catch where one part hooks over the other on the vertical part of the frame.
Not to everyone's taste I know as they don't quite look original but they do look a bit more secure (didn't stop some scrote from breaking the glass and nicking my recovery gear bag mind you). 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #1001785 25th Jul 2023 9:12pm
