Home > Puma (Tdci) > Diesel filters
Timcat
United Kingdom 2012 Defender 110 Puma 2.2 SW Indus Silver
Diesel filters
We are getting through diesel filters at a rate of knots! Always used genuine but we go through 6 a year due to the quality of fuel in certain parts of Africa.
At £50 a pop it’s not cheap! What’s everyone using & are they the same filtration? If it’s a case of only use genuine that’s what I’ll do.
Use genuine oil filters as they’re £15.50 each to buy in bulk & we are running a Nugget stuff Airbox so running a Mahle LX830 air filters in that.
Just had to run diesel cleaner through after Angola & the filter lasted 3k due to poor fuel!
Post #995960 12th Jun 2023 8:15am
hornet
If you have a look at https://www.autoteiledirekt.de/oenumber/wji500040.html you can identifiy prices and manufacture for that filter. I personally would not worry buying a cheap filter, but my fuel-quality ist premium. I use the MAHLE KC 204 which is half the price of genuine.
Post #995966 12th Jun 2023 8:37am
TexasRover
Just out of interest, how do you know the filter needs changing?
Post #995967 12th Jun 2023 8:42am
Timcat
I normally ask the locals when they change theirs ( I’m on the Angolan & Namibian landrover groups) but with ours you can feel it ( power is down & big hills are more of an issue) call me crazy but when I change the filter out it runs much better.
Also runs hotter, again might be me but changing the filter helps.
Post #995968 12th Jun 2023 8:53am
Timcat
Thanks Hornet, interesting looking at the costs & manufacturers Thumbs Up
Post #995969 12th Jun 2023 9:01am
spudfan
Ireland
I use MAHLE. Drain it every now and then to check for water, but I suppose it all comes down to the quality of the fuel. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #995980 12th Jun 2023 11:03am
Dutch
Germany 2007 Defender 110 Puma 2.4 SW Nato Green
I change the filter twice a year. Before winter -due to two frozen diesel lines in the past- and in spring.
Maybe it's overdone but it's only max 20 Euro each and I feel much better so:-)
Search for WJI500040 at autodoc-dot-co-dot-uk
The 2007 110 has reached 250k km on the clock, motor still sounds great, AGR is absolutly clean due to digital driver Laughing
Regards
Ron
Freshly dismantled
Cleaned
Post #999389 9th Jul 2023 10:33pm
Bluest
Personally, if I was in an environment where the fuel is routinely contaminated/dirty, I would stick with genuine filters if you can stomach the cost. They are clearly working well for you. The problem is, it's hard to know if an aftermarket filter meets the same standard for filtration as LR intended. If you can find the published micron ratings that would give some confidence. Being in the UK, I'm happy to use any of the name brands (Purflux, Mann, UFI etc), but it's not so critical here. For info, the filter head itself on the car is made by Purflux, so maybe their filters are a good match, but you'd need to check.
Have you considered a secondary fuel filter system like is popular in Australia? That could give you some piece of mind that if anything gets past the standard one it will be caught further down the line. That secondary one should last much longer as the fuel should be largely clean by the time it gets there.
https://www.tools.com/land-rover-defender-...fuel-manag 2007 110 TDCi Station Wagon XS
Post #999422 10th Jul 2023 9:48am
MK
OEM is Fuelmanager part #36995. 5 micron filtration. Puma 110" SW
Post #999465 10th Jul 2023 1:46pm
Timcat
I do like the look of the secondary fuel filter, if available I’d buy one of those but where & how you would put it in a pumas fuel line would be interesting.
I’ve gone for the Mahle fuel filters ( 5 micron) after asking some of the Namibian guys I know who do Angola & up the east coast regularly. Time will tell I suppose.
Post #1000212 15th Jul 2023 9:46am
NickMc
Mahle are about the best and what I use on my own stuff- I don’t like fram at all won’t touch them.
Post #1000268 15th Jul 2023 4:08pm
MK
This one is also available (#36994). But it could become clogged if the fuel is too dirty. Not sure.
 Puma 110" SW
Post #1000274 15th Jul 2023 5:03pm
Hgg
Kenya
Am running a second Racor filter in a 2.2 Puma and it works beautifully. Also in an area where fuel can get dodgy (East Africa)
Can take pics of it if interested
You can get it from South Africa with the required fittings
Post #1001213 22nd Jul 2023 10:52am
HardCharger
I've always fancied the idea of installing a second filter down the line from the factory filter with a system priming assembly. Very handy for the 2.4 owners as they will no loner need a specific tool just to prime the fuel system.
For those with a 2.2, this shouldn't be much of a concern since all y'all have an electric pump in the tank.
If anyone knows of an aftermarket solution like this, not sure if Racor has, please let us know.
Thanks! Thumbs Up
Post #1001471 24th Jul 2023 3:43am
If you extend the tank breather somewhere sensible you don't need a priming tool for a 2.4, you can simply blow or apply compressed air to pressurise the tank.
Post #1001475 24th Jul 2023 7:27am
